AP-1041N LWAPP reboot in a loop
Hi all!
We have a few AIR-LAP1041N-E-K9 and 2106 controller. One of the 1041N began rebooting in a loop. All over AP work fine.
This morning, AP normally loaded at once. Two hours later, after AP reboot, situation repeated itself.
Output from console:
using  eeprom values
WRDTR,CLKTR: 0x85000800 0xc0000000
RQDC ,RFDC : 0x80000037 0x0000018c
using ЪЪЪЪ ddr static values from serial eeprom
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x85000800, 0xc0000000
RQDC, RFDC : 0x80000037, 0x0000018c
Error resetting PCI Express phy on port 0
PCIE0 port 0 not initialized
PCIE1: link is NOT up.
PCIE1 port 1 not initialized
PCIEx: initialization done
flashfs[0]: 27 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 7364096
flashfs[0]: Bytes available: 25020928
flashfs[0]: flashfs fsck took 27 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 70:81:05:ec:45:70
Ethernet speed is 100 Mb - FULL duplex
Loading "flash:/c1140-k9w8-mx.124-23c.JA3/c1140-k9w8-mx.124-23c.JA3"...#############....
File "flash:/c1140-k9w8-mx.124-23c.JA3/c1140-k9w8-mx.124-23c.JA3" uncompressed and installed, entry point: 0x4000
executing...
enet halted
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 27 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 7364096
flashfs[1]: Bytes available: 24762880
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Radio0 not present 0 0 0 0 0 B
Radio1 not present 0 0 0 0 0 0
cisco AIR-LAP1041N-E-K9    (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1537Z0QF
PowerPC405ex CPU at 333Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 7.0.220.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 70:81:05:EC:45:70
Part Number                          : 73-14034-03
PCA Assembly Number                  : 800-34273-04
PCA Revision Number                  : A0
PCB Serial Number                    : FOC153176ET
Top Assembly Part Number             : 800-34284-02
Top Assembly Serial Number           : FCZ1537Z0QF
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1041N-E-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:09.557: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:09.569: *** CRASH_LOG = YES
*Mar  1 00:00:09.569: Port 0 is not present
*Mar  1 00:00:09.569: Port 1 is not presentSecurity Core found.
Base Ethernet MAC address: 70:81:05:EC:45:70
*Mar  1 00:00:10.179: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 41 messages)
*Mar  1 00:00:10.265:  status of voice_diag_test from WLC is false
*Mar  1 00:00:12.375: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:12.405: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1040 Software (C1140-K9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 14:52 by prod_rel_team
*Mar  1 00:00:12.405: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:09:06.060: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:09:06.060: bsnInitRcbSlot: slot 0 has NO radio
*Mar  1 00:09:06.060: bsnInitRcbSlot: slot 1 has NO radio
*Mar  1 00:09:06.269: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:09:06.961: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:09:15.269: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.168.37.177, mask 255.255.252.0, hostname AP7081.05ec.4570
*Mar  1 00:09:24.940: %PARSER-4-BADCFG: Unexpected end of configuration file.
*Mar  1 00:09:24.940:  status of voice_diag_test from WLC is false
*Mar  1 00:09:25.008: Logging LWAPP message to 255.255.255.255.
Translating "CISCO-CAPWAP-CONTROLLER.srv.int"...domain server (192.168.38.4)
*Jan 25 12:43:00.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.39.245 peer_port: 5246
*Jan 25 12:43:01.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 25 12:43:02.419: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.39.245 peer_port: 5246
*Jan 25 12:43:02.420: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.39.245
*Jan 25 12:43:02.420: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 25 12:43:02.569: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 25 12:43:02.572: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.39.245
*Jan 25 12:43:02.572: %DTLS-5-PEER_DISCONNECT: Peer 192.168.39.245 has closed connection.
*Jan 25 12:43:02.573: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.39.245:5246
*Jan 25 12:43:02.617: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 25 12:43:02.617: bsnInitRcbSlot: slot 0 has NO radio
*Jan 25 12:43:02.617: bsnInitRcbSlot: slot 1 has NO radio
*Jan 25 12:43:02.674:  status of voice_diag_test from WLC is false
*Jan 25 12:43:13.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.39.245 peer_port: 5246
*Jan 25 12:43:13.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 25 12:43:14.419: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.39.245 peer_port: 5246
*Jan 25 12:43:14.420: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.39.245
*Jan 25 12:43:14.420: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 25 12:43:14.560: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 25 12:43:14.563: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.39.245
*Jan 25 12:43:14.563: %DTLS-5-PEER_DISCONNECT: Peer 192.168.39.245 has closed connection.
*Jan 25 12:43:14.563: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.39.245:5246
*Jan 25 12:43:14.609: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 25 12:43:14.610: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 25 12:43:14.610: bsnInitRcbSlot: slot 0 has NO radio
*Jan 25 12:43:14.610: bsnInitRcbSlot: slot 1 has NO radio
*Jan 25 12:43:14.669:  status of voice_diag_test from WLC is false
*Jan 25 12:43:22.844: %CDP_PD-2-POWER_LOW: All radios disabled - NON_CISCO-NO_CDP_RECEIVED  (0000.0000.0000)
*Jan 25 12:43:23.844: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Jan 25 12:43:25.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.39.245 peer_port: 5246
*Jan 25 12:43:25.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 25 12:43:26.410: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.39.245 peer_port: 5246
*Jan 25 12:43:26.411: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.39.245
*Jan 25 12:43:26.411: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 25 12:43:26.555: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 25 12:43:26.558: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.39.245
*Jan 25 12:43:26.558: %DTLS-5-PEER_DISCONNECT: Peer 192.168.39.245 has closed connection.
*Jan 25 12:43:26.558: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.39.245:5246
*Jan 25 12:43:26.602: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 25 12:43:26.603: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 25 12:43:26.603: bsnInitRcbSlot: slot 0 has NO radio
*Jan 25 12:43:26.603: bsnInitRcbSlot: slot 1 has NO radio
*Jan 25 12:43:26.660: %PARSER-4-BADCFG: Unexpected end of configuration file.
*Jan 25 12:43:26.661:  status of voice_diag_test from WLC is false
*Jan 25 12:43:37.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.39.245 peer_port: 5246
*Jan 25 12:43:37.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 25 12:43:38.418: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.39.245 peer_port: 5246
*Jan 25 12:43:38.419: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.39.245
*Jan 25 12:43:38.419: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 25 12:43:38.559: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 25 12:43:38.561: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.39.245
*Jan 25 12:43:38.562: %DTLS-5-PEER_DISCONNECT: Peer 192.168.39.245 has closed connection.
*Jan 25 12:43:38.562: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.39.245:5246
*Jan 25 12:43:38.608: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 25 12:43:38.609: bsnInitRcbSlot: slot 0 has NO radio
*Jan 25 12:43:38.609: bsnInitRcbSlot: slot 1 has NO radio
*Jan 25 12:43:38.668:  status of voice_diag_test from WLC is false
*Jan 25 12:43:49.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.39.245 peer_port: 5246
*Jan 25 12:43:49.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 25 12:43:50.419: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.39.245 peer_port: 5246
*Jan 25 12:43:50.420: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.39.245
*Jan 25 12:43:50.420: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 25 12:43:50.559: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 25 12:43:50.561: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.39.245
*Jan 25 12:43:50.562: %DTLS-5-PEER_DISCONNECT: Peer 192.168.39.245 has closed connection.
*Jan 25 12:43:50.562: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.39.245:5246
*Jan 25 12:43:50.606: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 25 12:43:50.607: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 25 12:43:50.607: bsnInitRcbSlot: slot 0 has NO radio
*Jan 25 12:43:50.607: bsnInitRcbSlot: slot 1 has NO radio
*Jan 25 12:43:50.664:  status of voice_diag_test from WLC is false
What may be the problem ?
Thanks.
2 ACCEPTED SOLUTIONS
Re: AP-1041N LWAPP reboot in a loop
looks like a hardware problem. That BSN 0 not present looks like the AP is not able to detect the 2.4GHz radio. I'd call TAC and get an RMA
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hall of Fame Super Gold
Agree with Steve.  You have a hardware issue.  The 2.4 Ghz radio could be faulty.
Steve
Many thanks all !
We will request RMA.
Thank you for the ratings.
1717
