AP-1131AG radiation pattern
yuttana_su
Hi All
How should I mount an AP-1131AG for the best coverage area? vertical(wall) , Horizontal(ceiling).
Thank you.
jeff.kish
Level 7
Level 7
The 1131AG AP is meant to hang horizontally on the ceiling. The radiation pattern is an omnidirectional "donut", which extends out from the LED ring in the center.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
Waaaaay at the bottom is a description of the 1131 radiation pattern.
Thank you. Jeff
From the E-Plane radiation ,Can I mount on the wall ?. or If I mount on the middle of room (Vertical ) what is the effect?
Thanks you.
KO
You can hang it on the wall. The effect will be to change the polarity of the pattern by 90 degrees (to horizontal), which may or may not be detrimental, depending on the client.
Usually you'd be looking at ~3dB or so drop for a polarization mismatch.
Good Luck
Hi Scott,
Thank you for your advice.
