AP 1131AG
Hi all, is it possible to disable the light on an AP 1131 AG by software or if not by hardware^
Thanks.
Ben
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: AP 1131AG
Hi Ben,
Give this a try;
config ap led-state
To enable or disable the LED-State for an access point, use the config ap led-state command.
config ap led-state {enable | disable} {Cisco_AP | all}
Syntax Description
config
Display configurations.
ap
Advanced parameters.
led-state
Enable or disable the LED-State for an access point.
{enable | disable}
Enable or disable the access point's LED-State.
{Cisco_AP | all}
Name of a Cisco lightweight access point or all to specify all access points.
http://www.cisco.com/en/US/docs/wireless/controller/4.1/command/reference/clic1.html#wp2384867
Hope this helps!
Rob
Re: AP 1131AG
Hi Ben,
Give this a try;
config ap led-state
Syntax Description
config
ap
led-state
{enable | disable}
{Cisco_AP | all}
Hope this helps!
Rob
Re: AP 1131AG
Hi Rob,
Thanks a lot for your help.
You point me in the right direction.
The exact command for this model is :
config led display off
Thanks again and have a good day.
Ben
Re: AP 1131AG
Good stuff Ben! Thanks for posting back with your actual results (very helpful my friend :)
Cheers!
Rob
276
