AP 1200 SNMP OID for associated stations traffic and signal strength?
By viewing the web interface of the 1200, it lists the "To Station" and "From Station" number of packets (and errors, etc.). So that indicates there are counters tracking traffic for each.
What is the SNMP OID to retrieve this via SNMP so that we don't have to manually look up each associated device via the web page?
Also, there is the listing for signal strength, what's the OID to retrieve that via SNMP as well?
I've tried looking through the MIB 12.01T file, but it's very daunting when I do not know what variable(s) exactly I'm looking for.
Thank you.
Silver
Re: AP 1200 SNMP OID for associated stations traffic and signal
You can get the OID from the following location:
ftp://ftp.cisco.com/pub/mibs/v1/
So, which MIB file is it in? What would I search for through these large files to find the match, what it is referred to as?
Thanks.
Hi!
Type: OBJECT-TYPE
OID: 1.3.6.1.4.1.522.3.12.3
Full path: iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).oid_1_3_6_1_4_1_522(522).awcVx(3).awcForwardTbl(12).awcTpFdbTable(3)
Module: AWCVX-MIB
Parent: awcForwardTbl
First child: awcTpFdbEntry
Prev sibling: awcFtConfig
Next sibling: awcTpFdbDdpTable
Numerical syntax: Sequence
Base syntax: SEQUENCE OF AwcTpFdbEntry
Composed syntax: SEQUENCE OF AwcTpFdbEntry
Status: current
Max access: not-accessible
Sequences: 1: awcTpFdbAddress - MacAddress(4 - octets)
2: awcTpFdbClassID - AwcTpFdbClassID(2 - int, int32)
3: awcTpFdbSrcPktsImmed - Counter32(65 - cntr32)
4: awcTpFdbSrcOctetsImmed - Counter32(65 - cntr32)
5: awcTpFdbSrcErrorPktsImmed - Counter32(65 - cntr32)
6: awcTpFdbSrcErrorOctetsImmed - Counter32(65 - cntr32)
7: awcTpFdbDestPktsImmed - Counter32(65 - cntr32)
8: awcTpFdbDestOctetsImmed - Counter32(65 - cntr32)
9: awcTpFdbDestErrorPktsImmed - Counter32(65 - cntr32)
10: awcTpFdbDestErrorOctetsImmed - Counter32(65 - cntr32)
11: awcTpFdbDestMaxRetryErrorsImmed - Counter32(65 - cntr32)
12: awcTpFdbIPv4Addr - IpAddress(64 - ipaddr)
Description: A table that contains information about
entries for which the bridge has forwarding
and/or filtering information. This information
is used by the transparent bridging function
for maintaining statistics about each entry.
Type: OBJECT-TYPE
OID: 1.3.6.1.4.1.522.3.12.4
Full path: iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).oid_1_3_6_1_4_1_522(522).awcVx(3).awcForwardTbl(12).awcTpFdbDdpTable(4)
Module: AWCVX-MIB
First child: awcTpFdbDdpEntry
Prev sibling: awcTpFdbTable
Next sibling: awcDot11TpFdbTable
Base syntax: SEQUENCE OF AwcTpFdbDdpEntry
Composed syntax: SEQUENCE OF AwcTpFdbDdpEntry
Status: current
Sequences: 1: awcTpFdbDdpAddress - MacAddress(4 - octets)
2: awcTpFdbDdpSysName - DisplayString(4 - octets)
3: awcTpFdbDdpProdDevID - AwcDdpProdDevID(2 - int, int32)
4: awcTpFdbDdpRadioDevID - AwcDdpRadioDevID(2 - int, int32)
5: awcTpFdbDdpSwVerMajor - INTEGER(2 - int, int32)
6: awcTpFdbDdpSwVerMinor - INTEGER(2 - int, int32)
7: awcTpFdbDdpSwVerBeta - INTEGER(2 - int, int32)
8: awcTpFdbDdpUptime - Unsigned32(66 - gauge32)
9: awcTpFdbDdpNumAnnounceSent - Unsigned32(66 - gauge32)
10: awcTpFdbDdpNumAssociated - INTEGER(2 - int, int32)
11: awcTpFdbDdpLoad - INTEGER(2 - int, int32)
12: awcTpFdbDdpDistFromDS - INTEGER(2 - int, int32)
and/or filtering information. This table
maintains only Aironet-specific information
about each entry.
Type: OBJECT-TYPE
OID: 1.3.6.1.4.1.522.3.12.5
Full path: iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).oid_1_3_6_1_4_1_522(522).awcVx(3).awcForwardTbl(12).awcDot11TpFdbTable(5)
Module: AWCVX-MIB
First child: awcDot11TpFdbEntry
Prev sibling: awcTpFdbDdpTable
Next sibling: awcDot1dTpPortTable
Base syntax: SEQUENCE OF AwcDot11TpFdbEntry
Composed syntax: SEQUENCE OF AwcDot11TpFdbEntry
Status: current
Sequences: 1: awcDot11TpFdbAddress - MacAddress(4 - octets)
2: awcDot11TpFdbAID - Unsigned32(66 - gauge32)
3: awcDot11TpFdbClientState - AwcDot11ClientState(2 - int, int32)
4: awcDot11TpFdbTxShortRetries - Counter32(65 - cntr32)
5: awcDot11TpFdbTxLongRetries - Counter32(65 - cntr32)
6: awcDot11TpFdbLatestTxShortRetries - Counter32(65 - cntr32)
7: awcDot11TpFdbLatestTxLongRetries - Counter32(65 - cntr32)
8: awcDot11TpFdbRxWEPErrors - Counter32(65 - cntr32)
9: awcDot11TpFdbLatestRxSignalStrength - Unsigned32(66 - gauge32)
10: awcDot11TpFdbLatestRxSignalQuality - Unsigned32(66 - gauge32)
11: awcDot11TpFdbCapabilities - Unsigned32(66 - gauge32)
12: awcDot11TpFdbListenInterval - Unsigned32(66 - gauge32)
13: awcDot11TpFdbSupportedDataRates - OCTET STRING(4 - octets)
14: awcDot11TpFdbPreferredTxRate - Unsigned32(66 - gauge32)
15: awcDot11TpFdbCurrentBSS - MacAddress(4 - octets)
16: awcDot11TpFdbSSID - INTEGER(2 - int, int32)
17: awcDot11TpFdbVlanId - AwcVlanId(2 - int, int32)
maintains only 802.11-specific information
about each entry.
606
