Community Member
AP 1231G 12.3JA external antenna
I have a question about configuration for external antenna. In the setting of Radio0-802.11g i can enable parameters for external antenna. I need to enter a value in dB: Antenna Gain(dB)?
Which value can i put?
I'm using AP 1231G with an external antenna :AIR-ANT3213 (gain 5.2dBi) and a wire AIR-CAB020LL-R (1.3dBi).
thank you by advance.
1 REPLY
Community Member
Re: AP 1231G 12.3JA external antenna
I have my own answer:
http://www.cisco.com/en/US/products/ps5861/products_configuration_guide_chapter09186a00804158a8.html#wp1060543
This only use for management. There is no effect on the performance of the antenna.
Thank a lot.
I apolozise for this question.
484
