AP 1231G Not Passing DHCP to clients
Hello  My company AP 1231G is not passing the DHCP address to the client from the DHCP server  can you please advise on my config listed below
basicly the AP is on its own VLAN 10.1.123.1 and the DHCP server is 10.1.10.2 -- trying to use iphelper to pass DHCP to clients and the AP is on static IP 10.1.123.2--
! Last configuration change at 13:15:56 +0800 Fri May 25 2012 by root
! NVRAM config last updated at 13:15:56 +0800 Fri May 25 2012 by root
version 12.3
no service pad
service password-encryption
hostname XXXXXXXXXX
clock timezone +0800 8
ip subnet-zero
no ip domain lookup
ip domain name XXXXXXXXXXXXX
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 syslog
dot11 ssid XXXXXXXXXX
   authentication open
   authentication key-management wpa
   guest-mode
   infrastructure-ssid optional
   wpa-psk ascii XXXXXXXXXXXXXXXXXXXXXXX
dot11 arp-cache optional
username root privilege 15 password XXXXXXXXXXXXXXXXXXXXX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid XXXXXXXXXXX
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
no preamble-short
channel 2432
station-role root access-point
no dot11 extension aironet
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.1.123.2 255.255.255.0
ip helper-address 10.1.10.2
ip default-gateway 10.1.123.1
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
access-list 111 permit tcp any any neq telnet
snmp-server view dot11view ieee802dot11 included
snmp-server view ieee802dot11 ieee802dot11 included
snmp-server community public RO
snmp-server community private view undefined RW
bridge 1 route ip
line con 0
terminal-type teletype
line vty 0 4
sntp server 114.80.81.13
sntp broadcast client
end
Everyone's tags (6)
1 REPLY
Roan:
Where is your DHCP server configured (swtich, firewall, 3rd party server..etc)?
Does it work correctly if the AP IP on same subnet  and ip-helper is not being utilized?
Rating useful replies is more useful than saying "Thank you"
800
