AP 1242-AG
Mohammed Yusuf
By mistake I deleted boot file and now access point only boots up in ap mode.
When I run Dir I get nothing.
How can I restore the image back?
I have tried Hyper terminal xmodem but it failed.
I tried to assign IP address but it does not recognise the command but dir.
ap:
ap:
I need help and my access point.
how to load the controller-based "RCV" IOS into the AP and boot this IOS
1.  Download the RCV IOS from the Cisco website.  Make sure the IOS has a file extension of TAR.
2.  Copy the RCV IOS into the AP using the command "archive download-sw tftp:///IOS.tar".
3.  When the process finishes, reload the AP.
23 Replies 23
Scott Fella
Take a look at this guide. Should help you.
https://supportforums.cisco.com/docs/DOC-14636
-Scott
Which cable should I connect to Cisco AP device?
HI Mohammed,
You need to connect with Ethernet cable.
AP to PC
Mohammed Yusuf
Thanks all I got the file back and how would I link this one up with other access controllers?
Ok, now your AP is running on autonomous IOS.  You now need to load the controller-based "RCV" IOS into the AP and boot this IOS.
Once the switch boots into the RCV IOS, please post the following output:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh ip interface brief; and
5.  AP:  sh inventory
How would I do that Leo? how to load the controller-based "RCV" IOS into the AP and boot this IOS.
I have managerd to transfer tar file as you suggested and reloaded the AP.
Is it automatic supposed to connect with other AP ?
What other AP????
I thought you wanted the AP to connect to the WLC?
Mohammed Yusuf
Yeah how would it connect with WLC?
Have you restored the image?  If you haven't, then your AP is not going to work.  Have you looked at the deployment guides... there are many out there and depending if your AP is autonomous or if you have a WLC, you can find that info.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
let me check it seems to me they are all connected to each others and providing access for Scan Guns.
Mohammed Yusuf
Hi Scott,
Silly question how do I join to WLC and get the config.
