AP 1242 AG
I have to configure soma AP 1242 AG
but when they finished boot appeare on console :
%LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY, and I can't enter any command.
What's happen ?
There is IOS 12.3(11)JX1
best regards
Lorenzo
Hall of Fame Super Red
Re: AP 1242 AG
Hi Lorenzo,
The problem here is that the AP Model is an LWAPP or "Lightweight" AP designed to work with the WLC Lightweight Deployment. This is designated by the "LAP" prefix on the AP. You will need to convert the AP back to an Autonomous IOS "stand-alone" version;
These can be converted using the following method;
Using a TFTP Server to Return to a Previous Release
Note This section does not apply to Cisco C3201WMIC and Cisco C3201LAP.
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall, ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View > Show hidden files and folders.
Step 4 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, c1240-k9w7-tar.default for a 1240 series access point, and c1250-k9w7-tar.default for a 1250 series access point.
Step 5 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 6 Disconnect power from the access point.
Step 7 Press and hold MODE while you reconnect power to the access point.
Step 8 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 9 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 10 After the access point reboots, reconfigure it using the GUI or the CLI.
From this doc;
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
Hope this helps!
Rob
Re: AP 1242 AG
the instructions looks great but.. where can i get c1200-k9w7-tar.122-15.JA.tar or equivalent for my ap1242ag-e-k9?
Hall of Fame Super Gold
Re: AP 1242 AG
Hi Rob,
If the LAP has the RCV image, Lorenzo can delete the LWAP image and boot the RCV image instead.
PS: Congratulations on your brand-spanking new SILVER star!
Re: AP 1242 AG
902
