AP 1242-AG
By mistake I deleted boot file and now access point only boots up in ap mode.
When I run Dir I get nothing.
How can I restore the image back?
I have tried Hyper terminal xmodem but it failed.
I tried to assign IP address but it does not recognise the command but dir.
ap:
ap:
I need help and my access point.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
AP 1242-AG
how to load the controller-based "RCV" IOS into the AP and boot this IOS
1.  Download the RCV IOS from the Cisco website.  Make sure the IOS has a file extension of TAR.
2.  Copy the RCV IOS into the AP using the command "archive download-sw tftp:///IOS.tar".
3.  When the process finishes, reload the AP.
Hall of Fame Super Silver
Re: AP 1242-AG
Take a look at this guide. Should help you.
https://supportforums.cisco.com/docs/DOC-14636
-Scott
VIP Purple
Re: AP 1242-AG
Re: AP 1242-AG
Which cable should I connect to Cisco AP device?
VIP Purple
Re: AP 1242-AG
HI Mohammed,
You need to connect with Ethernet cable.
AP to PC
Re: AP 1242-AG
Thanks all I got the file back and how would I link this one up with other access controllers?
AP 1242-AG
Ok, now your AP is running on autonomous IOS.  You now need to load the controller-based "RCV" IOS into the AP and boot this IOS.
Once the switch boots into the RCV IOS, please post the following output:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh ip interface brief; and
5.  AP:  sh inventory
AP 1242-AG
How would I do that Leo? how to load the controller-based "RCV" IOS into the AP and boot this IOS.
AP 1242-AG
AP 1242-AG
I have managerd to transfer tar file as you suggested and reloaded the AP.
Is it automatic supposed to connect with other AP ?
AP 1242-AG
What other AP????
I thought you wanted the AP to connect to the WLC?
Re: AP 1242-AG
Yeah how would it connect with WLC?
AP 1242-AG
Have you restored the image?  If you haven't, then your AP is not going to work.  Have you looked at the deployment guides... there are many out there and depending if your AP is autonomous or if you have a WLC, you can find that info.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
AP 1242-AG
let me check it seems to me they are all connected to each others and providing access for Scan Guns.
Re: AP 1242-AG
Hi Scott,
Silly question how do I join to WLC and get the config.
VIP Purple
Re: AP 1242-AG
Hi mohammed,
You just connect the AP to your Infrastructure(edge swicth or...). AP will detect the config and image automatically from WLC.
FYI:
The LAPs are "zero touch" deployed, and no individual configuration of LAPs is required.
In order for the WLC to be able to manage the LAP, the LAP should discover the controller and register with the WLC. After the LAP has registered to the WLC, LWAPP messages are exchanged and the AP initiates a firmware download from the WLC (if there is a version mismatch between the AP and WLC). If the AP's onboard firmware is not the same as the WLC's, the AP will download firmware to stay in sync with the WLC. The firmware download mechanism utilizes LWAPP. Then, the WLC provisions the LAP with the configurations that are specific to the WLANs so that the LAP can accept client associations. These WLAN-specific configurations include:
  •     Service set identifier (SSID)
  •     Security parameters
  •     IEEE 802.11 parameters, such as:
  1.         Data rate
  2.         Radio channels
  3.         Power levels
AP 1242-AG
Exactly what have you done so far?
Re: AP 1242-AG
I have installed the iOS only and set the op address of fe0.
VIP Purple
Re: AP 1242-AG
do you have controller ???
If yes then please paste the output of the command from
WLC: sh sysinfo
AP: sh inventory
Paste the logs if u r having problem while connecting..
Regrdsa
AP 1242-AG
FE0?  You're suppose to assign an IP address to the AP's BVI.
Once you have done this, can the AP ping the management IP address of the WLC?  If it can, enter this command:  capwap ap controller ip address .
Re: AP 1242-AG
Hi fellas,
I have been learning a lot from you guys. I have borrowed 1242 access point to learn more but it has not antenna connected. I have bought antenna 1728 from ebay but do I need more than one antenna to configure?
Re: AP 1242-AG
You can use one, but you loose diversity.  You would have to define your receive and transmit antenna port.
Scott
-Scott
Re: AP 1242-AG
Can I use two 1728 2.4 ghz ? And be able to configure production Wi-Fi and guest? Do I need to buy 5ghz antenna as well?
AP 1242-AG
IT's up to you on what you need.... indoors, its nice to have diversity, but those antennas are really meant for high ceilings and usually used in warehouses.  Typical dipole antennas is what you would need for office areas.  Would I use the 5ghz also... of course, since many devices also support 5ghz.  Antenna doesn't have anything to do with your SSID's.  That is your configuration... your not going to say that you want production off one antenna and guest off the other.... doesn't work like that.  Antenna should be used depending on the environment the Ap is in and SSID, is your configuration of the AP.  With production and guest, you will need to have a switch that supports trucking.
Scott
-Scott
622
