AP 1300 Microsoft VPN
I have setup 2 Aironet 1300 (Version 12.3(2)JA4) for bridging ( ROOT and NON-ROOT).
The link work fine but the microsoft vpn client not work, i receice error 721.
If i attach the PC to wired network work fine THE Vpn.
There is some problem with PPTP in C1310-K9W7-M ?
Re: AP 1300 Microsoft VPN
The 721 error suggests that the remote peer is not responding... the software version that you are running
is pretty old.. try upgrading the software to the latest.. and another important thing is, make sure
there is no access-list which is blocking the wirless network subnet.
Let me know how this works out for you!!
Surendra
May be you are hitting one of these bugs.. CSCsk70798 or CSCtc78925
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsk70798
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtc78925
Please upgrade to the latest code for 1310 and let me know how this works out for you!!
Surendra
i try with some client (Windows 7,Window XP,Linux) and with the utility Pptpclnt and i not seen error.
Next week i try to upgrade ios on the AP.
Strange!!!! lets upgrade and see how it goes.. will be looking forward to hear from you!!
Surendra
i upgrade the ap 1300 with this version c1310-k9w7-tar.124-21a.JY , and the Microsoft Vpn Client works.
WOW!! Thats nice to hear and i am happy that the issue is resolved and i was of little help. thanks for using Community!!
have a great day!!
492
