AP 1310 setting 802.11b
Hi, the manual and the brochure of AP 1310 say that's possible to use the AP in 802.11b mode with 100 mW of maximum output power level but the the only working mode seems to be 802.11g @ 20 mW.
Is it really possible to change? Does anybody know how to do it?
Thanks a lot
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: AP 1310 setting 802.11b
Hi Manuel,
It looks like 20mw is the max for 802.11b. Have a look at this Field Notice;
Cisco Aironet 1300 Series
Field Notice: FN - 62021 - BR1310 Power Level Change
FROM THIS DOC;
http://www.cisco.com/en/US/products/ps5861/products_field_notice09186a0080537455.shtml
Hope this helps!
Rob
Please remember to rate helpful posts........
1 REPLY
Hi Manuel,
FROM THIS DOC;
Hope this helps!
Rob
236
