AP 1532i is not joined to WLC
We have an access point which has not joined WLC. The other APs were joined succefully but different version. We tried to change the image but still not joined!
System Bootstrap, Version U-Boot 1.1.4-gf5ee82b1-dirty Corfu , RELEASE SOFTWARE
Build Date: Oct 17 2013 - 18:08:55
corfu - Scorpion 1.0
DRAM:  256 MB
Now running in RAM - U-Boot at: 8ffbc000
Flash Manuf Id 0xc2, DeviceId0 0x20, DeviceId1 0x14
flash size 1MB, sector count = 256
Atheros on-chip NAND FLash Controller Driver, Version 0.1 (c) 2010 Atheros Communications, Ltd.
Ath Nand ID[8ffee17c]: 2c:f1:80:95:02
ONFI MICRON      MT29F1G08ABADAWP
Micron NAND 128MiB 3,3V 8-bit [128MB]
size = 128MB
Hit any key to stop autoboot:  0
boot_method is set to IOS_BOOT, boot IOS bootloader in NOR flash
Loading .text @ 0x84000000 (207840 bytes)
Loading .rodata @ 0x84032be0 (39008 bytes)
Loading .data @ 0x8403c440 (3264 bytes)
Loading .data.rel.local @ 0x8403d100 (1084 bytes)
Loading .data.rel @ 0x8403d53c (124 bytes)
Loading .data.rel.ro @ 0x8403d5b8 (960 bytes)
Clearing .bss @ 0x8403d980 (161116 bytes)
Clearing .scommon @ 0x84064edc (56 bytes)
## Starting application at 0x84000000 ...
IOS Secondary Bootloader - Starting system.HW Test Status(0)
Ath Nand ID: 95:80:f1:2c:00
Using driver version 1 for media type 2
Valid buffers 302
total302  302
success found all blocks
start end 73 137
found in range
high low end 4405 2358 137
Xmodem file system is available.
mifs[0]: 203 files, 11 directories
mifs[0]: Total bytes     :  131334144
mifs[0]: Bytes used      :   21690368
mifs[0]: Bytes available :  109643776
mifs[0]: mifs fsck took 1 seconds.
Base Ethernet MAC address: 78:da:6e:59:db:f8
Setup MAC....
Waiting for PHY auto negotiation to complete...Port 0 Negogiation success.
Ethernet speed is 100 Mb - FULL duplex
Scorpion  ----> F1 PHY *
: cfg1 0xf cfg2 0x7115
Loading "flash:/ap1g3-k9w8-mx.152-4.JB3b/ap1g3-k9w8-mx.152-4.JB3b"...###################################################################################################
File "flash:/ap1g3-k9w8-mx.152-4.JB3b/ap1g3-k9w8-mx.152-4.JB3b" uncompressed and installed, entry point: 0x60080000
executing...
Stop MAC.
Starting IOS...
cp0 timer begin value is set as 1000
prid= 19750
Starts main.
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1530 Software (ap1g3-K9W8-M), Version 15.2(4)JB3b, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 23-Jan-14 21:52 by prod_rel_team
Initializing flashfs...
Ath Nand ID: 95:80:F1:2C:00
Valid buffers 302
total302  302
start end 73 137
found in range
mifs[4]: 203 files, 11 directories
mifs[4]: Total bytes     : 131334144
mifs[4]: Bytes used      : 21690368
mifs[4]: Bytes available : 109643776
mifs[4]: mifs fsck took 6 seconds.
mifs[4]: Initialization complete.
...done Initializing flashfs.:pci_init_board:521 *** Warning *** : PCIe1 WLAN Module not found !!!
pci_rc2_init_board:570 PCIE Controller Init Bus Master Enable
:pci_rc2_init_board:593 PCIe2 WLAN Module Found !!!
soap_pci_subsys_init:706 Bus Master/Mem Enable on pci_write side
soap_pci_subsys_init(713): PCI vendor ID: 0x168C ret:0
soap_pci_subsys_init(715): PCI device ID: 0x33 ret:0
Disabling 802.3az feature on port 0
sgmii cal value = 0xE
Disabling 802.3az feature on port 1.
SGMII setup done, status is 0x3
Radio0  present 9550 9000 0 0 0 0
Rate table has 282 entries (12 legacy/96 11n/174 11ac)
Radio1  present 9590 9000 0 0 B2000000 1
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
%Error opening flash:/ap1g3-rcvk9w8-mx/info (No such file or directory)cisco AIR-CAP1532I-E-K9 (MIPS74k) processor (revision 26) with 204800K/57344K bytes of memory.
Processor board ID FCZ1814H01B
MIPS74k CPU at 700Mhz, revision number 0x0000
Last reset from power-on
LWAPP image version 7.6.95.12
2 Gigabit Ethernet interfaces
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 78:DA:6E:59:DB:F8
Part Number                          : 74-11942-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC18080A0H
Top Assembly Part Number             : 000-00000-00
Top Assembly Serial Number           : FCZ1814H01B
Top Revision Number                  : 23
Product/Model Number                 : AIR-CAP1532I-E-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:17.951: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (11)mips74k_config_radio_pci(302): PCI CMD write: 0x356
*Mar  1 00:00:22.799: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to upEnterprise mode: 0x44000000
*Mar  1 00:00:23.299: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (2)
*Mar  1 00:00:23.375: ath_load_ctl_pwr_tbl() dot11radio 2G loading CTL binary flash:/ap1g3-k9w8-mx.152-4.JB3b/CO2.bin version# 3.0
*Mar  1 00:00:23.731: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (2)
*Mar  1 00:00:23.731: ath_load_ctl_pwr_tbl() dot11radio 5G loading CTL binary flash:/ap1g3-k9w8-mx.152-4.JB3b/CO5.bin version# 3.0
*Mar  1 00:00:23.879: CDP_PD: Power Source: Negotiable PoE Switch
*Mar  1 00:00:24.855: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar  1 00:00:26.631: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:26.631: %SNMP-5-COLDSTART: SNMP agent on host AP78da.6e59.dbf8 is undergoing a cold start
*Mar  1 00:00:26.871: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:26.875: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:26.875: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:26.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:29.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:45.191: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:45.203: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:45.203: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:01:04.023: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.124.128.108, mask 255.255.255.0, hostname AP78da.6e59.dbf8
Translating "CISCO-CAPWAP-CONTROLLER.nor.ad.salvationarmy.org"...domain server (10.123.0.11) [OK]
*Mar  1 00:01:14.899: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:14.919: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'NORWLC5508'running version 7.5.102.0 is rejected.
*Mar  1 00:01:14.919: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:14.919: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:14.919: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:14.919: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.123.6.31
*Mar  1 00:01:24.915: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'NORWLC5508'running version 7.5.102.0 is rejected.
*Mar  1 00:01:24.915: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:24.915: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:24.915: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:24.915: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.123.6.31
*Mar  1 00:01:32.887: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3560-48PS (001b.0c69.781d)
*Mar  1 00:01:34.915: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'NORWLC5508'running version 7.5.102.0 is rejected.
*Mar  1 00:01:34.915: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:34.915: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:34.915: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:34.915: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.123.6.31
*Mar  1 00:01:44.915: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'NORWLC5508'running version 7.5.102.0 is rejected.
*Mar  1 00:01:44.915: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:44.915: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:44.915: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:44.915: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.123.6.31
Not in Bound state.
*Mar  1 00:02:00.407: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:02:00.419: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'NORWLC5508'running version 7.5.102.0 is rejected.
*Mar  1 00:02:00.419: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:02:00.419: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:02:00.419: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:02:00.419: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.123.6.31
*Mar  1 00:02:05.291: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:02:05.399: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.124.128.108, mask 255.255.255.0, hostname AP78da.6e59.dbf8
*Mar  1 00:02:11.407: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:02:11.415: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'NORWLC5508'running version 7.5.102.0 is rejected.
*Mar  1 00:02:11.415: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:02:11.415: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:02:11.415: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:02:11.415: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.123.6.31
*Mar  1 00:02:21.415: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'NORWLC5508'running version 7.5.102.0 is rejected.
*Mar  1 00:02:21.415: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:02:21.415: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:02:21.415: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:02:21.415: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.123.6.31
*Mar  1 00:02:31.419: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'NORWLC5508'running version 7.5.102.0 is rejected.
*Mar  1 00:02:31.419: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:02:31.419: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:02:31.419: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:02:31.419: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.123.6.31
Any suggestion?
1 ACCEPTED SOLUTION
VIP Purple
Hi,1532 AP need the minimum
1532 AP need the minimum software version on wlc must be 7.6.100.0
And you have 7.5.102.0 on your WLC, This is the error on your logs:
Check the compatibiliy Matrix: http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Update to 7.6.100.0 or higher version on wlc  and then try to connect it.
Dont forget to rate helpful posts
VIP Purple
Hi Sandeep Sounds correct
Hi Sandeep
Sounds correct answer.
Tonight I'll update WLC, and will see what happen :)
Thank you!
516
