AP and Clients on same VLAN
Hi guys, i'm having some connectivity problems with an 1231 AP, and i have some question for you:
Is ther a problem if the AP and the clients are on the same segment (vlan)? I have a configuration that looks like this:
interface Dot11Radio0
no ip address
no ip route-cache
ssid Control
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.16
encapsulation dot1Q 16 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.16
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.16.250 255.255.255.0
no ip route-cache.
I know the recommendation is to have one vlan for administration and different vlans for clients, but is this just a recommendation or it just wont work?
Thanks in advance!!
1 REPLY
Green
Re: AP and Clients on same VLAN
It's "just" a security recommendation.
The AP acts as a bridge (~L2) and doesn't care what the L3 address (i.e., IP) it is assigned.
Aside from management, it doesn't need an IP address at all.
"Management" in this case also refers to authentication; if you are using (or are intending to use) an external authenticator (like RADIUS), then an IP address on the AP would be required.
Good Luck
Scott
121
