Bronze
AP c1252 config assistance
First time playing with c1252 and I got some issues.
1.I enabled all the high throughput rates, set WMM policy to 'Allowed' under WLAN and tested with open authenticated WLAN under 2.4g. But I only got 65M on both Linksys 300N card and a Macbook. What could be the problem?
2. Under "Higher Throughput" MCS settings, do I need to set all the rates to 'supported'? Any benefits to support rates lower than 58Mbps here?
3. We use c3750E switch and I can see both A and B/G radios are up for the AP. But the AP only draw 15.4 watts from the switchports, not 18.5 watts as expected. Is it the problem?
Thanks!
Zhenning
Bronze
Re: AP c1252 config assistance
I figured it out. The lower data rate I got is caused by the AP not drawing full power from the switch.
First I need to upgrade my switch to 12.2(44)SE to support Enhanced PoE.
Then the AP still draws 15.4 watts with automatic power negotiation. I have to use follwoing commands under swtich port level:
power inline static
power inline port max 20000
Then the AP draws 20watts and I got 130Mbps.
So everyone has to manually set power maximum 20watts for 1252 APs? Anyone has it working using automatic?
And I don't see it is documented anywhere in CCO!
Zhenning
Bronze
Sorry after several minutes, the speed drops down to 65Mbps again.
Any suggestions?
Hall of Fame Super Silver
I have a Linsys600N and can only get around 130mbps and that is sitting next to the ap. A Mac book got the same link speed, but had a higher throughput than what I was getting on the 600N. Why does it drop... who knows, I think when they get something standard instead of a draft, things will work better. Try using different channels and play around with the 600N card settings, that is what I did.
-Scott
Bronze
My Macbook also gets 130Mbps. Maybe an issue with 300N card.
It can be.... use iperf and test the throughput.... that is another thing you will be amazed with.
-Scott
152
