AP disconnect issue
Hi forumers'
i experienced this problem
log copy from WLC : AP  'XXXXX', MAC : e8.ba.70.93:95:99  disassociated previously due to AP reeset. Last reset reason: oeprator changed 11g mode
sometime it will auto recover and joined, else need to manually unplug and plug in again..
AP model is 1040 series, WLC running on 7.0.116.0 firmware, power source is direct from power injector.
Anyway can solve this problem?
Noel
AP disconnect issue
Did it happen only once ? or does it happen regularly ? Aren't some people changing WLC config like data rates ?
AP disconnect issue
How frequently the AP getting rebooted
Is AP mode HREAP/local
If H-REAP, does AP reboots while moving from connected to standalone if b/g is disabled
Do you have redundant WLC, does the B/G datarate different or disabled on other WLCs where this AP can roam.
Does this issue occur when the AP moves to different WLC
AP disconnect issue
This happen on-and-off. There's no branch and HREAP.
The site don't have the redundant WLC.
Would it cause by physical cabling issue? How i going to troubleshoot on this
Noel
AP disconnect issue
I would check a few things.
Check the switch port for errors
Check the switch logs for any activity on the ports that have the aps
Is it the same aps doing this or is it the same aps on teh same switch
Also check the join statics on the side. That could show you some behavior anyway. clear it out and then monitor.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
553
