AP-G-A HWIC not recognized in my 1841
I am having problems with my 1841 router recognizing my HWIC-AP-G-A wireles card. I am running the following IOS: c1841-advsecurityk9-mz.124-3g.bin. I have tried placing it in slot0 and slot1. Any ideas?
Thanks!
1 REPLY
Hall of Fame Super Red
Re: AP-G-A HWIC not recognized in my 1841
Hi Shawn,
Here is a clip from Ben's (from Cisco) excellent post (he knows ALOT more about this than I ever will :)
The HWIC-AP is supported with the 1841, but you must be running a 12.4T IOS image (in addition to the correct feature set). I'd suggest 12.4(11)T with Adv. Security or Adv. IP Services Feature Set. Make sure you meet the minimum memory requirements as well.
Your next best option would be 12.4(9)T2 with either Adv. Security or Adv. IP Services Feature Set."
Hope this helps! This should definitely work.
Rob
368
