08-21-2008 09:58 AM - edited 07-03-2021 04:21 PM
I have AP Groups enabled so when users connect to SSID 'X' in one building they get an IP address from one vlan, and when they connect to SSID 'X' in another building they get an IP address from another VLAN.
The problem I am running into is that SSID 'X' is assigning an IP address from the vlan that is assigned to the original WLAN, and not the one assigned in the AP Group.
I'm 99% sure that the AP Group VLAN mappings are supposed to override the original VLAN to SSID mapping.
I have one laptop that I can connect to the SSID and get an IP address from the AP Group assigned VLAN, all other laptops I test on that SSID get IP addresses from the original VLAN to SSID mapping.
Anyone seen this or have any suggestions?
08-26-2008 09:50 AM
Are both VLANs available to the controller via the allowed list on the trunk? I'm assuming that both building's VLANs can be seen by the switch connected to the controller.
10-16-2008 11:52 AM
You might want to look at "wlan overide" on your access points. You can setup different interfaces w/vlan tagging that are associated with a specific wlan/ssid. You then can specify which ssid will be used at specific access points.
10-16-2008 01:43 PM
Actually, Tkhan is right here. WLAN override only serves to limit which WLANs a specific AP radio broadcasts. Check your trunk links to ensure that VLANs are all configured properly. If you're using the management interface for your WLAN, your clients will all DHCP on the native VLAN of your trunk link.
Be warned, though. Some clients may have issues when roaming from one building to the other. Cisco controllers do not support L3 roaming, and a client may experience a sharp hiccup when trying to get an address after moving to the next building.
