AP join to AP-Manger IP
Hi all:
i meet a problem is that all my lightweight ap join the controller with AP-Manager IP but i pretty sure the DNS a record is point to the management ip of controller ,not the AP-Manager IP.
The log show as below :
*Aug 11 19:11:12.470: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Aug 11 19:11:12.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.1.42 peer_port: 5246
*Aug 11 19:11:13.402: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.1.42 peer_port: 5246
*Aug 11 19:11:13.403: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.1.42
*Aug 11 19:11:13.403: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Aug 11 19:11:13.408: %DTLS-5-ALERT: Received WARNING : Close notify alert from 172.16.1.42
*Aug 11 19:11:13.408: %DTLS-5-PEER_DISCONNECT: Peer 172.16.1.42 has closed connection.
Please help to verify and let me know what's the problem here, thanks a lot!
Gold
Re: AP join to AP-Manger IP
That is the correct behavior. The AP sends a discovery request to the management interface of the controller. The controller responds with all of the ap-manager interfaces. The AP picks the best one and sends the join request to the ap-manager to build the LWAPP tunnel. It is done this way because depending if you are running LAG or not you could have multiple ap-manager interfaces configured.
Completely normal behaviour.
Hi dancampb :
Many thx for your message , i am clearly now. But My controller still close the AP join request by the error log as below :
*Aug 11 20:01:01.289: Join resp: Unable to encode CAPWAP Control IPV4 Address
*Aug 11 20:01:01.289: 00:21:d8:44:29:b0 Failed to encode Join response to 172.16
.73.54:29282
*Aug 11 20:01:01.290: 00:21:d8:44:29:b0 Config Response Failure: Unable to send
Join response to 172.16.73.54:29282
*Aug 11 20:01:01.292: 00:21:d8:44:29:b0 State machine handler: Failed to process
msg type = 3 state = 0 from 172.16.73.54:29282
*Aug 11 20:01:01.292: Failed to process CAPWAP packet from 172.16.73.54:29282
*Aug 11 20:01:01.292: Failed to process packet from 172.16.73.54:29282
*Aug 11 20:01:01.295: Discarding non-ClientHello Handshake OR DTLS encrypted pac
ket from 172.16.73.54:29282)since DTLS session is not established
Many thx for all of your help , Please help to see the error in my WLC and i attach the capwap log file from WCL.
Hall of Fame Super Silver
Console into the AP and apply this command below. It will make it join the WLC and quickly reboot. See if this works
test capwap controller ip x.x.x.x
-Scott
hi fella5 :
As i have 100 more Lightweight AP , Any method i can make ap join wcl without console ?
i console to one AP and i can see the ap ip address , gateway , controller ip is correct and controller ip point to controller management ip address. Would you mind let me know i also need to use your command or not ?
582
