AP-MANAGER'S CONNECTION CONFUSION
wirelessman
hello wireless experts!!!
need some light shed on this.
5508 configured with LAG disabled
ap-manager2 - 8 configured diff ip same vlan with management int (dynamic ap still checked on mgt int, vlan 0)
ap1142 connected to switch (no/def config, vlan 1)
switch directly connected to 5508 on ap-manager2 int (port 2).
output: ap not able to register to wlc.
will this work, i mean without the mgt int connected to the switch where 1142 is connected?
is there any more config missed?
cisco dox said, disabling LAG and creating 7 ap-manager interfacess will be able to connect to 7 diffrenet switches.
this will be implemented on multiple floor/switches. where should the mgt int be connected if there's one switch on 1st floor and  another switch on 2nd floor?
2 Accepted Solutions
Oh wow, I totally missed that in the picture.
Absolutely no way will that work.
The WLC is not a switch. Your 3 switches MUST have physical network functioning between them in order for any of this to work.
I didnt realize you disconnected your switches so they are not connected to each other.
Connect switch 2 and 3 to each switch 1 and everything will work.
Again,  your APs MUST be able to talk through the network to the management interface. So from Switch 3 to Switch 1 to Management Interface.
What are you trying to accomplish anyhow?
Multiple AP-Managers is used for Switch Redundancy.  If you are trying to get the APs on Floor 2 to only use the AP-Manager on Floor 2,  that isn't going to work.
You cannot control which AP manager your APs are connected to.  So if you did connect all switches together (like picture 1)  and then you connected WLC to all 3 switches,   your APs on Floor 3 might be joined to AP-Manager on switch 1,  and APs on switch 1  might be joined to AP-MGR on switch 3.....
Either way, it all requires that you have network infrastructure in place that allows you to talk to Management Interface from wherever you plug you switch in to the network.
Now, there is a VERY SLIM off chance that you can make this work like a "directly connected AP"   kind of like what one might do on the 2106.   You could ocnnect an AP to a port (that DOES NOT have any interface assigned to, including ap-mgr) and the 2106 would bridge traffic over for APs to join. I seriously doubt that functions on a 5508, and I am almost certain its not supported if it did.....
So, get your switches connected to each other like they need to be, and then if you really need switch redundancy connect the wlc to each switch in addition.
Where is your router in all this? Normally we see switch redundancy to the distribution or core layer, not just to the access layer....
12 Replies 12
Scott Fella
You do have the management interface connected to a switch on the same vlan as the ap manager, correct.  The vlan must also be able to reach from the managment to the ap manager.  Initial connection is to the managment until the AP joins, then it uses the AP Manager.
-Scott
Hi Scott,
Tnx for your reply.
When LAG was enabled.... yes! untagged vlan on controller and vlan1 on the switch. the mgt int is connected to a stacked switch which is having 6 fiber links intended fo other floors fiber1 - switch on ground floor.. fiber2 - switch on second floor and so on.... and all ap's are registered and working as planned.
Now, LAG is disabled, ap-manager2 - 8 int's were created, fiber2 is pulled from stacked switch and plugged it to port2 of controller. with this, there isn't mgt connection to switch on second floor. it's like the AP is directly connected to port2.
dhcp is on the controller, but the ap is not able to get an ip.
will a second fiber connection from second floor switch to the stack switch be the best way for this?
Is there a trunck connection from the switch the management port is connected to and the switch the ap and the ap manager is connected to?  The management needs to be available for dhcp.
-Scott
Hello Scott,
To illustrate clearly (i hope i can) kindly refer to the following images.
Scenario 1 below is currently working fine.
Scenario2 below is not working, at least for floor 2 and 3. As setup.. . the switches on the the other floors are connected directly to the controller's ap-manager interfaces without any reachability to the management interface. can the ap-manager interfaces able to reach the management interface in this way? will dhcp be available in this way of connection to the ap's on the other floors?
the management interface is only connected to the switch on the ground floor.
Thank you, Scott!
Probably a better way to word this is to just use "port" instead of ap-manager interface.
An AP-Manager interface maps to specific port, but a specific port doesn't just map to an ap-manager (in your scenario it may, but it is still confusing to word it that way).
Correct me if I'm wrong, but basically Port 1 goes to Switch 1, Port 2 goes to Switch 2, Port 3 goes to Switch 3.
And you are saying that It works fine if Port 1 is the only port connected...?
There is nothing wrong with that picture you've provided.
As long as your APs can talk to the Management Interface, the Management interface is going to tell the AP which AP-Manager IP they should try to join. The AP will then try to talk to the AP-Manager it was instructed and as long as it can, it should be functional.
So, where is your AP Join failing?  Can the AP not talking to the WLC Mangement IP?
Can the AP not talk to the AP-Manager?
What are you using for AP Discovery, assuming these are new APs not working?
Thanks, weterry!
With the first image.... as mentioned... everything is working fine
With the second, where lag is disabled, since the management interface (Port1) of wlc is connected to the ground floor switch, it is the only floor where ap's are working fine.
the ap's on floor 2 and 3, where the switches are directly connected respectively to ap-manager 2 (Port 2) and ap-manager 3 (Port 3) of wlc, aren't able to register back to the controller. from the initial setup, image one, the ap's got registered to the controller and working as planned. but when the fiber links of floor 2 and 3 switches were moved  from the ground floor switch to port 2 and port 3 respectively of the controller, the ap's aren't registering back.
Whe you said "There is nothing wrong with that picture you've provided." does this mean that the ap's can be plugged direct to port 2 or port 3 and will be able to get an ip from the wlc dhcp? there isn't a need for management link  on floor 2 and 3 switches?
Not directly related to your issue but just a friendly reminder. You shoud TAG all your interfaces. Although config guides 3 - 6 state other wise. Config guide 7 does state to tag and this is cisco best pratice.
If you do QoS you will lose all priority on the managment and the AP mangers because they are native. Other wise instead of just trusting CoS you will need to do policy maps.
Maybe Scott and Wes can comment on this .. I may be wrong but ...
Although you break the APs by floor they may not logically map like that. Once the AP joins the controller it will learn about the other AP managers and will join those if needed.
Thanks, George!
For sharing your knowledge.
The ports and interfaces aren't tag yet.... I will try tagging them ports and interfaces when i get back to our lab.
In the meantime, will connecting the ap's direct to the ap-manager interface (port 2 and port 3) work? considering, of course, that LAG is disabled.
BINGO!
Thanks, weterry!
Thanks for clearing up that directly connecting the AP's to WLC will not work.
This is actually for one of our customer who's kind of reading the Cisco Config Guide as well. This feature is included in their RFP in which all ports in the controller must be used for redundancy, failover and load distribution between ap's.
This idea lifted off from the Cisco Wireless Config Guide, pp 3-36, which says:
In partic and to quote "With multiple AP-manager interfaces, you can connect your ports to different neighbor devices. If one of the neighbor switches goes down, the controller still has connectivity."
Plus, the load is distributed dynamically across multiple ap-manager interfaces.
BTW, the router is connected via switch 1, which is actually a stacked switch. didn't include it in the drawing for simplicity.
I will get them switches connected to the distribution switch (switch1) like they need to be. or maybe i'll just enable LAG and configure my favorite interface, port-channel interface, on the distribution switch.
Many thank you's, Weterry!
