05-22-2012 03:24 AM - edited 07-03-2021 10:11 PM
I have a Cisco aironet 1040.
On my Accespoint i have 2 vlans: 1 for my wifi phones and 1 for my network.
Wifi Lan has the SSID LAN with WPA enterprise authentication to a radius server(ms server 2008).
Wifi Phone has SSID PHONE and vlan 50 with local radius authentication.
This Works all fine, Except when i enable AP for my wifi phones.
When AP is enabled the authentication for my lan doesn’t go to my server but local.
How do I configure my accesspoints so that the cisco phones use the local radius server with AP and my windows computers connect using the ms radius server?
Hope some one can help
Attached is my current config.
05-25-2012 06:59 AM
Ok. The config we the working on, it's the WDS master? Once you have the wlccp configured do a show WDS ap and make sure the other ap are joined.
Steve
05-31-2012 01:08 AM
Steve,
The problem is the WDS authentication, is there maybe a solution to only use WDS authentication for my wifi phones?
