Community Member
AP registered into WLCs
Hi I have two Wireless LAN Controller version 4.2, and the 1131 access point. The WLC number is called WLC01 and the name of the second WLC is WLC02. In the access points the Primary Controller Name and the Secondary Controller Name are configured as WLC01 and WLC02. The problem is that when the WLC1 (for example) fails the access points are not re-register in the WLC01, these remain registered in the Secondary Controller. To resolve this problem I restart the access point and these are registered in your primary wireless controller.
Hall of Fame Super Red
Re: AP registered into WLCs
Hi Ricardo,
The design for redundancy with LWAPP and the WLC's involves the addition of a common Mobility Group. Have a look at this good doc;
WLAN Controller Failover for Lightweight Access Points Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008064a294.shtml#c4
Hope this helps!
Rob
Hall of Fame Super Gold
Hi Ricardo,
How or what method did you use to configure the Primary and Secondary Controller?
It WILL NOT WORK if you configured the parameters using the HTML/GUI method. Why? Because it's a bug. You can verify this by going using the CLI on the WLC: sh ap config general .
On the 2nd page, look at the entries of the Primary Cisco Switch Name and the Primary Cisco Switch IP Address.
To get this to work, you need BOTH the WLC name and the WLC IP Address. In the HTML/GUI it will only take EITHER the WLC name or the WLC IP Address. So the only way to get this to work in the 4.X.X IOS is to go through CLI (I know how painful it is): config ap primary-base
This bug was finally fixed after the 5.0 IOS.
Hope this helps.
Community Member
Hey guys, Thx for this. Do we have a bug ID?
Many thx
Ken
Hi Ken,
Unfortunately, I did not get/remember the bug ID.
Community Member
We have one 1 WLC running 5.0.148.0 but still unable to make the PRIMARY/2ndary setting to work. We have configured it but its not running ... Does this version still have the problem ?? Can't find anything in the caveat for this version and the 1 after this....
If you are talking about the "Global" settings, YES. A bug for the 5.0.X exist. Individual APs, NO. They've fixed this.
Hope this helps.
266
