Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
AP's Disassociating
4402 - Ver 5.1.151.0
AP 1242
I keep receiving these errors from WCS about my AP's dropping
AP 'AP NAME' disassociated from Controller 'CONTROLLER IP'. (6 times)
Then 2 minutes later I get another message that it associated. This will happen many times through out the day. When I look at the controller there are 3 traps that keep coming up. They are.
AP's Interface:0(802.11b) Operation State Down: Base Radio MAC: Cause=Admin Configured
AP's Interface:1(802.11a) Operation State Down: Base Radio MAC: Cause=Detecting in-line power
AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:Cause=Heartbeat Timeout
I have another controller with the same software version with 1242 connected and dont have this problem.
Would would cause the problem with this specific controller and AP's?
Re: AP's Disassociating
Do you have AP fallback disabled on the controller that you are having issues with?
No, it is enabled.
How are these being powered? Are all these patched back to the same switch or more than 1 switch?
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Powered by 2 PoE switches. I have a total of 10 APs that are plugged into the 2 switches and when they drop, they all drop.
do they all drop at the same time or randomly. Have you tried debug any of the events?
They all pretty much drop at the same time. Here is some of the errors from the eventlog on the AP. You will see at the bottom that it drops, then reconects.
*Jun 15 15:20:23.272: %LWAPP-3-CLIENTERRORLOG: Retransmission count for packet e
xceeded max(ECHO_REQUEST
, 1)
*Jun 15 15:20:23.273: %LWAPP-3-CLIENTERRORLOG: GOING BACK TO DISCOVER MODE
*Jun 15 15:20:23.273: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Jun 15 15:20:23.274: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
dministratively down
*Jun 15 15:20:23.274: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to a
*Jun 15 15:20:23.274: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 15 15:20:23.275: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jun 15 15:20:23.275: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Jun 15 15:20:23.305: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 15 15:20:23.307: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Jun 15 15:20:23.334: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jun 15 15:20:23.335: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Jun 15 15:20:23.365: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
--More-- or (q)uit
*Jun 15 15:20:33.283: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Jun 15 15:20:33.284: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
*Jun 15 15:20:33.284: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to a
*Jun 15 15:20:34.283: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
0, changed state to down
1, changed state to down
*Jun 15 15:20:38.294: %LWAPP-3-CLIENTERRORLOG: Join Timer: did not recieve join
response (controller - MVD-WLC)
*Jun 15 15:20:38.295: %LWAPP-3-CLIENTERRORLOG: Set Transport Address: no more AP
manager IP addresses remain
*Jun 15 15:20:43.305: %LWAPP-3-CLIENTERRORLOG: Join Timer: did not recieve join
*Jun 15 15:20:43.305: %LWAPP-3-CLIENTERRORLOG: Set Transport Address: no more AP
*Jun 15 15:20:48.344: *** Access point reloading. Reason: DID NOT GET JOIN RESPO
NSE ***
*Mar 1 00:01:02.221: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar 1 00:01:02.221: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to ad
ministratively down
*Mar 1 00:01:02.221: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to ad
ministratively down
*Jun 15 15:21:37.929: %LWAPP-5-CHANGED: LWAPP changed state to CFG
*Jun 15 15:21:43.007: *** Access point reloading. Reason: DID NOT GET CONFIG RES
PONSE ***
What model of switch are these access points connected to? Since you mentioned that this is a POE switch, see if the url below helps:
http://www.cisco.com/en/US/docs/wireless/controller/5.1/configuration/guide/c51lwap.html#wp1111701
Nagendra
3560's. Ill check out the URL..Thanks
What size controller(s) and how many aps?
4402 - 25 licenses
10 AP's connected.
Hall of Fame Super Gold
*** Access point reloading. Reason: DID NOT GET CONFIG RESPONSE ***
Has any one of the 1242 AP's joined the controller before?
Yes they have. For example all of my AP's were connected yesterday. Then over night they disassociated/associated several times.
Try the new firmware, 6.0.182.0, and see if this improves things. If not, then you can always run the secondary image on the WLC.
I did upgrade the firmware to 5.163.0 and things have been a little better...now the AP's are only dropping overnight.
You said you have another WLC that works just fine. Try on making the other APs there register to the WLC that's having problems. And try to register the APs that are dissasociating to the working WLC. From here, maybe we can get some ideas why you're having those problems.
Im working on an install this evening and i have a similar issue...
Get this ...
I have 30 AP1220s. These are setup to joing controller 1 for (first) controller 1 for (second) and controller 1 for (third) attempt. For testing..
The APs are on controller 2.
When you enable fallback these APS attempt to join controller 1, but cant. So they bounce... and stay on controller 2.
I disable failback and everything is fine...
i will sniff the ap tomorrow to see what it says ...
interesting .. wondering if there is a bug on the older aps...
in my case its the 1220's ONLY that wont move...
1196
