Community Member
AP's failed during LWAPP upgrade.
I recently did a conversion of 125 AP's, both 1231's, 1121's and 1242's this past month.
The problem is I have about 10 that didn't get joined to the controller. It seems like a SSC issue but i'm not sure because I see the ssc on the controller. I tried to go back to autonomous mode so I could run the upgrade tool again but that didn't seem to work.
Here is an attachment of the log file.
When I console into the AP I get the following:
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:41 by alnguyen
*Mar 1 00:00:05.457: %LINK-3-UPDOWN: Interface FastEthernet0, changed state top
*Mar 1 00:00:06.457: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEtherp
*Mar 1 00:00:23.536: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:23.566: SSC Load Current Size crypto_mykey 116, offset 3520, Save4
*Mar 1 00:00:23.566: SSC Load Current Size crypto_mykey 116, offset 4499, Save4
*Mar 1 00:00:31.683: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned 5
Translating "CISCO-LWAPP-CONTROLLER.jdnet.deere.com"...domain server (172.20.47]
*Mar 1 00:00:37.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
*Mar 1 00:00:45.799: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar 1 00:00:53.799: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not re
*Mar 1 00:00:53.799: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses.
*Mar 1 00:01:01.835: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not re
*Mar 1 00:01:01.835: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses.
*Mar 1 00:01:02.013: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload R.
*Mar 1 00:01:02.013: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
I don't believe it's an AP manager IP error because I can convert other autonomous AP's fine.
Greg
1 REPLY
Hall of Fame Super Silver
Re: AP's failed during LWAPP upgrade.
I have had issue during a conversion, but I was able to convert the ap back to automomous and then was able to upgrade the ap to LWAPP. So the logs are from a WLC that has ap's on it correct? You time is correct and are you sure that the SSC is entered correctly. If you try to downgrade back to autonomous, then stick with this code or a 12.3:
c1200-k9w7-tar.122-15.JA.tar
-Scott
131
