AP seems to be bricked
One of my customers gave me an old AIR-AP350 series access point.
When you power it on it gives 3 solid amber lights, then flashes 3 solid red lights, then 3 solid green lights and then all activity stops as far as the indicator lights go. I don't get any response at all through the ethernet port and I get nothing through the serial port.
Is there anything I can do with this or is it junk?
Re: AP seems to be bricked
Yes, the problem is I can't find any physical reset button on the device, and I get nothing out of the console port. Nothing, no output from the device like it is booting up, so I can't start to boot and hit escape.
Try different baud rates on the console.
187
