AP template fails to propogate to APs -MEDIATION-1
I am trying to build a template for our AP-1010 access points. Whenever I click the "apply" button, I get an error message that says the following in the the 802.11b/g Parameters area: Failure: MEDIATION-1, Attempt to set conflict attribute value, LradIf,antennaGain,LradIf!<Mac-address>!1
I am still learning as I go. Any help would be appreciated.
konrad
2 ACCEPTED SOLUTIONS
Silver
Re: AP template fails to propogate to APs -MEDIATION-1
Are you using the WLSE or the WCS?
Silver
The error looks like it is erroring pushing antenna information as part of the template. If that is correct, can you try disabling the antenna selections and try again?
-Eric
Please remember to rate all helpful posts.
Silver
Silver
-Eric
I got it. It was pushing the antenna info which it did not need. thanks.
261
