Community Member
AP1030 Bridge has troubles rejoining
AP1030
WiSM 3.2.116.21
I have an AP1030 that is losing connectivity to poor SNR. (I'm fixing that, the antenna was installed incorrectly)
However, while Diagnosing it, I found this in the message logs
Wed Aug 23 18:30:49 2006 [ERROR] spam_lrad.c 1799: AP 00:0b:85:63:97:30 associated. Last AP failure was due to Configuration changes, reason: did not get join response
Wed Aug 23 18:29:12 2006 [ERROR] spam_lrad.c 1553: spamProcessJoinRequest : spamDecodeJoinReq failed
Wed Aug 23 18:29:12 2006 [ERROR] spam_crypto.c 1509: Unable to free public key for AP 00:0B:85:63:97:30
Wed Aug 23 18:29:12 2006 [ERROR] spam_lrad.c 4698: LWAPP Join-Request Bridge Authentication Failed for AP 00:0b:85:63:97:30
Wed Aug 23 18:29:12 2006 [ERROR] spam_lrad.c 4233: LWAPP Join-Request AUTH_STRING_PAYLOAD, invalid BRIDGE key hash AP 00:0b:85:63:97:30
Wed Aug 23 18:12:36 2006 [ERROR] spam_tmr.c 501: Did not receive hearbeat reply from AP 00:0b:85:63:97:30
Zero touch config is enabled right now. But this error message makes me worry that when I disable it, the AP will not rejoin.
Is there anyway to fix this?
1 REPLY
Community Member
Re: AP1030 Bridge has troubles rejoining
That is normal, I have seen AP's do that a lot after a configuration change on the controller. In your case the antenna. Don't worry about it.
117
