AP1131 won't show up after WLC upgrade
I just upgraded WLC 4402 from 5.2 to 6.0, but after reboot, I can see all the AP's are "downloading" software, and then all gone, they won't show up any more.
Please help!
Re: AP1131 won't show up after WLC upgrade
Message: Invalid Configuration detected by XML
Controller time base status - Controller is out of sync with the central timebase...
Hall of Fame Super Gold
Check the time of your WLC, it may not have sync-ed with an NTP source.
Set the correct time or NTP source and check again.
Please check at the AP console for debugs. Enable "debug capwap client events" on AP
Also make sure , you have capwap ports open .
Vinay
Ok now. I added a new IP scope last week, and all APs received new ip addresses from this new scope - different subnet from managment-port.
879
