Community Member
AP1140 - Power Doubt
I would like to know if could you power supply  that i used whit my AP 1130  with my new AP 1140?
Also is possible to convert LWAP 1140 to  IOS 1140 ?
Best Regards
MC
Re: AP1140 - Power Doubt
To answer your question easily..
YES - Both power supplys will work
YES - 1140 can do both IOS and LWAPP
Please rate helpful post.
Hall of Fame Super Gold
Power bricks, yes.  Won't work with Injector 2 or 3.
Hey Bud,
What are you looking for exactly? Here is a link on the 1142. It has a good amount of links for you readin pleasure
http://www.cisco.com/en/US/products/ps10092/prod_literature.html
433
