02-20-2006 11:53 AM - edited 07-04-2021 11:39 AM
I have multiple ap's in a library, all settings left to defualts(mostly) POE, primary antenna only, random clients lose connection and cannot see ap and have to be re-added by local admin before they will see ap again. any suggestion??
more info??
02-24-2006 02:02 PM
Can you give some more information on what exactly the problem is.. What do you mean when you readded to the local admin. To you have a WLSE.
02-28-2006 06:50 AM
the wireless service on the machine is ran through windows and i have to add the ap becuz we use ssid, so it has to be added through the wireless network tab in properties of net conn.
02-28-2006 01:22 PM
periodically the pc's lose the ap and lose connection. but as soon as you login to admin it picks it back up and you can then lob out, log back into generic accounts and it will work. its almost as if the ap is being cached in the pc and is timing out.
