AP1200 VxWorks FW upgrade
I rolled out the latest VxWorks FW (12.04) to our 6 APs and the change is reflected in the header of the user interface. However, when you go to the FW update page where it shows you what version you are currently running, it shows the old version (12.03). I have done warm and cold resets to see if it will reload but there is no change. Has anyone else experienced this? Any ideas?
Thanks.
Sheldon
1 REPLY
Anonymous
N/A
Re: AP1200 VxWorks FW upgrade
104
