09-11-2003 07:28 AM - edited 07-04-2021 09:00 AM
When using an AP1200 do I need to install one or two standard dipole antenna (2dBi)?
Thank you!
Rouven
09-18-2003 06:04 AM
Refer the following URL for information,
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/ap120hig/12higd_3.htm
09-19-2003 06:21 AM
You can install 1 or 2 antennas. When you use 2 antennas the AP needs to be set up as using diversity antennas. This is usually the default. If you use only one set it up to use just the 1 antenna. Diversity antennas gives the reciever 2 reference points of signal to enable it to get a good recovered signal in the case of multi-path or delay spread on the signals reaching the AP.
