AP1230 Hot Standby
I'm trying to set an AP1230 to be the backup of another AP1230. They both have the same configuration execept for IP address and in the back-up unit I enabled the HOT STANDBY feature.
The standby unit shows status as timeout and it does not seem to be working as I expect. Of course when I turn the monitored unit off my client is switching to the standby unit not because the standby feature but I believe it is because they have the same SSID.
If you played with Standby Mode please let me know how it works. Thanks!
Re: AP1230 Hot Standby
Please check out this link it describes how it is meant to work and aslo how to verfiy it is working
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1100/accsspts/i12211ja/i12211sc/s11rep.htm#1037483
David
Thanks for your answer but I have one more question
Should I use the MAC address for the Radio or the MAC address for the FastEthernet?
Thanks again!
116
