AP1231 does not hand out DHCP IP to clients
I have an ap configured to handout DHCP to the wireless clients. This is what I see on the pix.
#debug ip dhcp server packet
*Mar 7 23:51:21.172: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0009.5b83.47d6 Associated KEY_MGMT[WPA PSK]
*Mar 7 23:51:21.284: DHCPD: DHCPDISCOVER received from client 0100.095b.8347.d6 on interface BVI1.
*Mar 7 23:51:25.290: DHCPD: DHCPDISCOVER received from client 0100.095b.8347.d6 on interface BVI1.
*Mar 7 23:51:32.293: DHCPD: DHCPDISCOVER received from client 0100.095b.8347.d6 on interface BVI1.
*Mar 7 23:51:49.308: DHCPD: DHCPDISCOVER received from client 0100.095b.8347.d6 on interface BVI1.
The client never gets an IP. Here is my config. Thanks in advance!
#sh run
Building configuration...
Current configuration : 3800 bytes
version 12.3
no service pad
service password-encryption
hostname widgets1
enable secret xxxx
enable password xxxx
username xxx privilege 15 password xxxx
ip subnet-zero
ip domain name
no ip dhcp conflict logging
ip dhcp excluded-address 10.4.1.240 10.4.1.254
ip dhcp pool widgets
network 10.4.1.0 255.255.255.0
default-router 10.4.1.254
lease 10
no aaa new-model
dot11 ssid widgets
authentication open
authentication key-management wpa
infrastructure-ssid optional
wpa-psk ascii xxxx
crypto ca trustpoint TP-self-signed-479015087
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-479015087
revocation-check none
rsakeypair TP-self-signed-479015087
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid widgets
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.1.1.1 255.255.255.0
no ip route-cache
ip default-gateway 10.1.1.254
no ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
control-plane
bridge 1 route ip
line con 0
access-class 111 in
transport preferred all
transport output all
line vty 0 4
access-class 111 in
login local
transport input all
line vty 5 15
access-class 111 in
login
transport input all
end
1 REPLY
Re: AP1231 does not hand out DHCP IP to clients
I think this is because your IP address 10.1.1.1/24 is on a different network to the IP DHCP scope 10.4.1.0/24. Try changing the IP DHCP pool to 10.1.1.0/24 and exclude any necessary addresses.
An alternative is to create multiple VLAN-SSID mappings so that you can use 10.1.1.1/24 for bvi 1 and 10.4.1.0/24 for the WLAN users in a seperate VLAN-SSID.
Hope this helps
134
