Bronze
AP1231G and guest ssid
standalone AP1231G running c1200-k9w7-mx.123-8.JEC2 setup with internal SSID (VLAN 24)and guest SSID (VLAN 124). Here's the problem
Both SSID picks up the native VLAN 1 dhcp address and not it's respective VLAN. I verify that dhcp server is working on vlan 24 and 124 on the switch but on the AP it always stays with Vlan 1. The AP can ping all vlan interface on the router. DHCP server hangs off the router.
topology is 3725(with NMD-36-ESW port 2/2) trunk to AP. Below is the relevant configs:
*************3725***************
interface FastEthernet2/2
switchport trunk native vlan 9
switchport mode trunk
interface Vlan1
description Data
ip address 10.7.1.254 255.255.255.0
interface Vlan9
description MANAGEMENT
ip address 10.7.9.1 255.255.255.0
ip helper-address 10.7.1.10
ip helper-address 10.7.1.11
interface Vlan24
description WIRELESS
ip address 10.7.24.1 255.255.255.0
interface Vlan124
description *****WIRELESS GUEST*****
ip address 10.7.124.1 255.255.255.0
**************AP CONFIGS***********
aaa group server radius rad_eap
server 10.0.21.121 auth-port 1812 acct-port 1813
aaa group server radius rad_acct
aaa authentication login eap_methods group rad_eap
aaa accounting network acct_methods start-stop group rad_acct
dot11 vlan-name rms-guest vlan 124
dot11 vlan-name wavenet vlan 24
dot11 ssid rms-guest
vlan 124
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 <removed>
dot11 ssid wavenet
vlan 24
authentication open eap eap_methods
authentication network-eap eap_methods
accounting acct_methods
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 124 mode ciphers tkip
encryption vlan 24 mode wep mandatory
broadcast-key vlan 124 change 360
ssid rms-guest
ssid wavenet
interface Dot11Radio0.1
description MANAGEMENT AND NATIVE
encapsulation dot1Q 9 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.24
description WAVENET SSID
encapsulation dot1Q 24
no ip route-cache
bridge-group 24
bridge-group 24 subscriber-loop-control
bridge-group 24 block-unknown-source
no bridge-group 24 source-learning
no bridge-group 24 unicast-flooding
bridge-group 24 spanning-disabled
interface Dot11Radio0.124
description RMS-GUEST SSID
encapsulation dot1Q 124
no ip route-cache
bridge-group 124
bridge-group 124 subscriber-loop-control
bridge-group 124 block-unknown-source
no bridge-group 124 source-learning
no bridge-group 124 unicast-flooding
bridge-group 124 spanning-disabled
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.24
no ip route-cache
bridge-group 24
interface FastEthernet0.124
no ip route-cache
bridge-group 124
interface BVI1
ip address 10.7.9.10 255.255.255.0
no ip route-cache
ip default-gateway 10.7.9.1
ip radius source-interface BVI1
radius-server host 10.0.21.121 auth-port 1812 acct-port 1813 key 7 <removed>
bridge 1 route ip
1 REPLY
Silver
Re: AP1231G and guest ssid
Is it possible that you're VLAN hopping? VLAN 1 is normally the native VLAN, and you have VLAN 9 configured. Check your config carefully and make sure that your native VLAN on all your uplinks is consistent, assuming there are any uplinks. What you posted appears correct, though.
Honestly, I don't see a problem with the configuration your posted. You might want to reset the device to factory defaults or upgrade the IOS to ensure it's not a bug.
You aren't using dynamic VLAN assignment, are you?
Let us know if you figure it out, I'm curious what's going on here :D
713
