08-19-2006 09:22 PM - edited 07-04-2021 12:52 PM
The AP1242 is a brand new LWAPP version.
Below are the error message when the AP try to join the WLC:
*Mar 1 00:00:46.659: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
examining image...
Loading file /c1240...
Unable to create temp dir "flash:/update"
*Aug 20 12:43:44.068: %LWAPP-5-CHANGED: LWAPP changed state to IMAGE
*Aug 20 12:43:45.114: lwapp_image_proc: encounter flash problem, retry here
*Aug 20 12:43:45.115: lwapp_image_proc: encounter flash problem, retry here
*Aug 20 12:43:45.141: %SYS-5-RELOAD: Reload requested by lwapp image download pr
oc. Reload Reason: Reason unspecified.
*Aug 20 12:43:45.141: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
%Error opening (Protocol error)archive download: takes 6 seconds
Current info for WLC2006:
Image version 3.2.78.0
IOS version 12.3(11)JX1
Current info for AP1242:
LWAPP image version 3.0.51.0
Anyone had this problem before ? Please help.
CMYip
Solved! Go to Solution.
08-22-2006 08:09 PM
Thanks for your update. I suspect it is the WLC firmware issue, try to uprade it to the latet ver. (4.0.1550). Please advise the result after upgrade it. Thx.
08-19-2006 10:00 PM
Looks like the AP has passed through the discovery and join phases but is having issues with the image download. The usual suspect for this issue is a regulatory domain mismatch between the AP and the controller. For example, if you set your controller for "US" as the regulatory domain and you have an AP configured for, say, Japan (-J).
08-20-2006 08:32 PM
Thanks for the reply. If i look at the model of my AP (AIR-LAP1242AG-C-K9), it regulatory domain is from China. I don't see a way to do the setting (changing) in IOS for the regulatory domain or i miss out something ?
For my WLC (AIR-WLC2006-K9), I believe the regulatory domain is change using the country command. If my AP regulatory domain is from China, do i had to chose the China country for my WLC country setting even I in a different country (Malaysia)?
Please help.
CMYip
08-22-2006 01:45 AM
Anyone had updated info on the above problem ? Jakew, any idea ?
Thank you.
CMYip
08-22-2006 07:33 PM
Are the time sync. between WLC and AP ? I have a question, if the AP and WLC come w/ the same IOS, why still download the image ?
Moreover, you can try to upgrade the WLC to latest image first then try again.
I have an autonomous 1242 then using upgrade tool to upgrade to LWAPP and able to communicate to the 2006 w/o any problem.
Hope this helps.
08-22-2006 08:07 PM
The AP is already a LWAPP version when it arrived. It not an autonomous by default. So, the upgrade tool is of no use here.
The AP had the LWAPP image version 3.0.51.0 and my WLC image is version 3.2.78.0.
I don't known why it still download the image even the IOS is the same. But my real issue is that the AP can't associate with my WLC, hence the problem.
I had try to change the clock (can change) but i can't save it (no command to save the config). Once reboot the AP clock go back to default (March 01 2006). I believe the LWAPP AP version is a read only IOS image if we configure it through the console (read somewhere from the Cisco Web site).
I also suspect the problem could be the WLC image is not up to date.
Will ask the vendor to update the image and try again to setup it up.
CMYip
08-22-2006 08:09 PM
08-22-2006 10:14 PM
Hi..
I had the same problem before.. I just upgraded my WLC2006 to version 3.2.116.21.
Then later upgraded again to version 4.0.155.5.
Btw, please see to it you have DHCP running and no ip conflicts..
08-22-2006 11:26 PM
We had confirm that the DHCP is running fine with option 43 in the same subnet as the WLC and AP. Look at the below for full error message with the DHCP assigned IP.
*Mar 1 00:00:06.230: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power s
ource
*Mar 1 00:00:06.239: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.3(11)JX1, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:44 by alnguyen
*Mar 1 00:00:07.191: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar 1 00:00:08.191: %LINEPROTO-5-UP
ap>DOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar 1 00:00:16.190: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
*Mar 1 00:00:25.245: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:33.384: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address x.x.x.75, mask 255.255.255.0, hostname AP0019.0665.2288
*Mar 1 00:00:46.651: LWAPP_CLIENT_ERROR_DEBUG: spamHandleDiscoveryTimer : Found
the discovery response from MASTER Mwar
examining image...
*Aug 20 12:43:50.141: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
CMYip
08-22-2006 11:46 PM
Is it possible to create the "update" directory in flash manually ?
And, did you upgrade the WLC to latest ver. ?
08-22-2006 11:56 PM
Yes, i had try to manually create the "update" directory without problem in the flash (AP unit) and reboot but the error message is still the same.
Regarding upgrading the WLC image to the latest version, since we are on the end-user and we don't have the Smartnet subscription, we can't login to download the software. Had to depend on our vendor to obtain the latest image version for us.
Will keep you guy inform once the vendor downloaded the latest image for us.
Thanks.
CMYip
08-23-2006 12:42 AM
Many thx. Wait for your update.
08-26-2006 08:45 PM
For the updates, we had just upgraded the WLC2006 images to ver 4.0.155.5 and the problem solved ! No more complaint or error from the AP.
Thanks for all the reply.
CMYip
08-27-2006 04:44 PM
This is great ! Thanks for the updates. Jack
