AP1262 and AP1252
Does LAP 1262 must be connect WLC? or  1262 can be used as alone as AP1262?
AP1262 and AP 1252 are all belongs to LWAP? and must be controlled by WLC?
What‘s the different between AIR-AP1252AG-x-K9 and AIR-LAP1252AG-x-K9 ???  urgent need help?
AP1252 can used alone? just connect Switch and configuration can be working?
LAP1252 must be connected by WLC, and without IOS can be setting? cannot used alone with WLC??
2 ACCEPTED SOLUTIONS
Re: AP1262 and AP1252
Currently 1262 is LWAPP only and needs WLC. however 1252 has both LWAPP and autonomous image.. 1262 doesnt have Autononmous image..
lemme know how this answered ur question
Surendra
Surendra is all correct.
For the 1250 the different between AP1250 and LAP1250 is the software image running on it when you receive it.
If you order a AP1250, it will come with IOS image and you will be able to run it without WLC. If you order a LAP1250, it will come with a lwapp/capwap image that will require WLC.
Note however that the hardware is IDENTICAL. You can thus re-image a AP1250 with an lwap/capwap image and make it work with a WLC and you can also re-image a LAP1250 with IOS to make it run standalone.
The trick is that the 1260 has no standalone IOS image at all.
Nicolas
Don't forget to rate answers that you find useful
Surendra
Nicolas
Thanks for you all reply. that's useful for me..
My vendor pointed this out last night -- the 1262s now have IOS/Autonomous version in the software download section. Software was release just last December.
I will try to convert a lightweight to this version over the weekend.
Do you know who to process this IOS to AP1262??  how to import it into Ap1262??
If your 1262 is currently lightweigth (CAPWAP) , then to put IOS on it :
connect to the AP via console, go to enable mode
type "debug capwap console cli"
type "archive download-sw /f /o tftp://"
Boom, it restarts as IOS standalone :-)
Hi, no command what you said:
AP1cdf.0f**.***1#debug capwap ?
  client  CAPWAP Client Debug Options
  mcast   CAPWAP MCAST Debug Options
  mfp     CAPWAP MFP Debug Options
AP1cdf.0f94.ba91#debug capwap client ?
  config          CAPWAP Client Config Messages
  detail          CAPWAP Client Detail Messages
  error           CAPWAP Client Error Messages
  event           CAPWAP Client Event Messages
  fwd             CAPWAP Client dot11 forwarding
  hexdump         CAPWAP Client Hexdump Messages
  info            CAPWAP Client Info Messages
  lsc             CAPWAP Client LSC Events
  mgmt            CAPWAP Client dot11 mgmt
  packet          CAPWAP Client Packets
  payload         CAPWAP Client Payload Messages
  probe           CAPWAP Client dot11 probe
  reassembly      CAPWAP Client Fragment Reassembly
  tcp-mss-adjust  CAPWAP client MSS adjust
  tcp-mss-print   CAPWAP Client MSS print
AP1cdf.0f**.***1#archive?
% Unrecognized command
There is a New Capwap 1262, But no IOS.  So I want to import IOS into, do you know who to do this??
AP1cdf.0f**.***1#sho flash
Directory of flash:/
    2  -rwx           0   Mar 1 2002 00:27:46 +00:00  config.txt
    3  -rwx         185   Jan 1 1970 00:00:38 +00:00  env_vars
    9  drwx         128   Mar 1 2002 00:26:28 +00:00  ap3g1-rcvk9w8-mx
31481856 bytes total (29198336 bytes free)
AP1cdf.0f**.***1#
ar  1 00:32:55.999: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:32:55.999: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP
. Renewing DHCP IP.
it's a hidden command so it doesn't appear with the question mark.
Did you just try to type it ?
I have try, it's working,  But access tftp get some error:
P1cdf.0f**.***1#copy tftp://10.1.1.2/ap1262-k9w7-mx.124-25d.JA flash:
Destination filename [ap1262-k9w7-mx.124-25d.JA]?
Accessing tftp://10.1.1.2/ap1262-k9w7-mx.124-25d.JA...
%Error opening tftp://10.1.1.2/ap1262-k9w7-mx.124-25d.JA (Socket error)
AP1cdf.0f9**.***1#
I have downloaded new IOS image for AP1262:  ap3g1-k9w7-tar.124-25d.JA.tar
But don't know how to import this Image to AP1262, and then AP1262 can be running at standalone without WLC..
Yes, , But I just connect my laptop to the AP from Console, How to setup
tftp for this AP can download ios from my Laptop, I have already setup tftp
server in my computer: tftpd32
Thank you.
On Wed, Mar 2, 2011 at 6:13 PM, ndarchis <
Connect your PC to the network and the AP to the network too. If the AP gets an ip address via DHCP it has network connectivity. you can then download the image from your PC ip address.
it's ok now, Thank you very much
AP1262#sho flash
*Mar  1 00:30:44.859: %SYS-5-CONFIG_I: Configured from console by console
    2  -rwx        6168   Mar 1 2002 00:28:23 +00:00  private-multiple-fs
    3  -rwx         279   Mar 1 2002 00:33:54 +00:00  env_vars
    4  -rwx        1377   Mar 1 2002 00:28:23 +00:00  config.txt
    5  -rwx       22600   Mar 1 2002 00:33:54 +00:00  event.log
    6  -rwx           5   Mar 1 2002 00:28:23 +00:00  private-config
    7  drwx         512   Mar 1 2002 00:33:52 +00:00  ap3g1-k9w7-mx.124-25d.JA
31481856 bytes total (25015296 bytes free)
AP1262#sh
Hall of Fame Super Gold
3109
