07-20-2009 10:05 AM - edited 07-03-2021 05:50 PM
Hi, I have 20 1522AG's in lightweight mode running on a 4400 controller. Firmware is all 6.0.
My issue is that the wireless interfaces on these access points are frequently going down and then immediately back up. This happens on each access point multiple times a day.
The AP itself does not lose power or reboot, nor does the controller. I simply get this message:
802.11b/g interface of AP123 is down: Controller 192.168.47.3
It usually clears with minutes, but sometimes longer, like hours.
I've run a syslog on the controller, and all I get is interface up/down messages, no explanation.
Could this be a mesh or CDP issue or something?
Thank you
07-20-2009 03:07 PM
Make sure that the link margins between the APs are properly calculated. Second, insure that the APs are properly registered to the controller, third insure that power is not an issue. Lastly, how did your site survey look? Any interference sources?
07-21-2009 07:51 AM
Are all the access points configured to be in the same BGN? How many access points are configured as root? Sometimes, if a mesh access point can hear from multiple parent aps, it might cause an issue.
Nagendra
