AP350 and AP1200 Telnet questions. Pre IOS versions
I have about 180 APs that I need to download their ini files and add SNMP privileges to two user accounts. I know how to do this with the GUI but would like to speed up the process by using telnet. Does anyone know what commands I could use?
1 REPLY
Silver
Re: AP350 and AP1200 Telnet questions. Pre IOS versions
If you do not enter security information in the conversion template and User Manager is enabled in the AP, you might not be able to log in on the upgraded AP through Telnet, the console port, or the browser. If this occurs, you must reset the AP to its defaults. In this Console/Telnet. Only the Enable and Disable settings are migrated.
142
