Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
AP350 and transmit power
I can't configure a transmit power of 100mW on my AP350,max is 50mw
I've installed firmware 11.23T (radio 4.25g) no change
Did i forget something somewhere to validate this transmit power?
Alain
Re: AP350 and transmit power
When adquiring AP's in the ETSI ZOne, the higher output power you can use is 50 mW, to avoid using higher EIRP than the allowed by ETSI. If you had an US device, you could use this 100 mW configuration. Somewhere in the device you'll find a label telling it's and etsi device (typical German)
It is possible to modifiy an ETSI AP350 to deliver 100mW ?
Or the two modeles (US and ETSI) have different hardware ?
Thanks for answering
Franck
Maximum output power on the 350 is 50mW (17dBm) however it is normal to use antennas of approximately 2-3dB gain which then takes you up to maximum isotropic output power of 100mW (20dBm). (17 + 3 =20dBm).
160
