Community Member
AP350 - Radio Firmware: 4.25a, how to update ?
Hello, i am a bit confused, how i can upgrade the Radiofirmware of an AP350 ? the installed version is 4.25a, I use System Firmware: 11.21.
Where to get the file for the RadioFirmware ?
Why my AP350 shows the following @boottime :
h) FLASH :340 Series FWare 04.25a FE1BB0B4 53608 .tar.gz Data 0000
why he use FWare from the 340 Series ?
thanks
andrew
1 REPLY
Re: AP350 - Radio Firmware: 4.25a, how to update ?
Actually radio firmware for AP340 and 350 is the same so you may see AP350 using firmware for AP340..Only difference between them is the radio hardware..
Now here is the place which document upgrading procedure for AP340 which is the same for AP350.
http://www.cisco.com/warp/public/102/wlan/ap-fw-upgrade.html
Now here it the place from where you can get the firmware for them
http://www.cisco.com/pcgi-bin/tablebuild.pl/aironet-340
and
http://www.cisco.com/pcgi-bin/tablebuild.pl/aironet-350
Thanks..Tejal
167
