03-26-2014 03:38 PM - edited 07-05-2021 12:33 AM
Can not find any reference to this msg
%APF-4-INVALID_ACTION_CATEGORY: apf_wme_utils.c:5297 Could not process 802.11 Action. Received Action frame with invalid category field(not supported by controller) from client. Mobile:40:F0:2F:8C:19:E7, Category:4.
Has anyone experienced this before ?
Solved! Go to Solution.
03-27-2014 12:13 AM
The wireless client was using a subset of 802.11 feature that were not supported by the WLC. You can ignore this type of logs.
regards
03-27-2014 12:13 AM
regards
03-27-2014 04:12 AM
Tks
