Apple Airplay not working on WLC 4402 wireless network........how can it solve !!
bashundhara
I have  a WLC 4402 wireless network ............. i want to enable Airplay service
keep Management, AP Manager, client connecting wlan mapped vlan on same L2 subnet if not already and try.
7 Replies 7
Dirk Woellhaf
did you enable any of the Multicast-Services on the controller? What does your setup look like?
regards,
    Dirk
regards, Dirk (Please rate if helpful)
Scott Fella
Also take a look at this doc
https://supportforums.cisco.com/docs/DOC-21728
-Scott
To further add to Dirk/Scott,  since this is a 4402 there is the option of either Unicast mode or Multicast mode for  Multicast Delivery. The easiest method if scale isnt a problem is to just enable multicast unicast mode.   If you choose multicast multicast mode, then you will need to make sure that multicast routing works in the wired infrastructure (might work if APs and WLC are in the same vlan...)....
the multicast-mode just referes to the connection/delivery between the controller <--> access-point. It doesn´t matter if the multicast is send in unicast or multicast to the ap.
Check if IGMP-Snooping is disabled, etc.
By the way: Multicast is not yet supported over an anchor-tunnel.
regards,
    Dirk
@ Drik ....... thanks   for reply i enable Multicast service....... i also enabled Multicast-routing in my Switch, where AP mangement VLAN r created .........
in vlan interface
configure......... # IP PIM DANS-MODE
also disible IGMP- Snooping .but not working .
The main problem is In in my netwrok i have airport express..... i joined airport express as friendly AP in WLC ..... so neighbourship is done......... hand-over process is doing well.... but Airplay option can not show when user goes in CISCO AP coverage area.............
@Saravanan thanks .......................... work is done................
