Apple TV vs WLC on ISM-SRE-300
Hello!
Apple TV doesn't work over WiFi provided by WLC installed on ISM-SRE-300 module.
Apple TV server and iPad are situated in one L3 segment, Ipad can ping Apple TV
WLC and 2911 router are configured according to this doc
https://supportforums.cisco.com/docs/DOC-24187
http://www.cisco.com/en/US/docs/wireless/controller/controller_modules/sre/installation/guide/wlcsreinst.html#wp1072764
Router 2911
Version 15.2(2)T
WLC
7.0.230.0
Vlan 1 and vlan 50 (for clients) are configured on 2911 router.
2911 config:
ip multicast-routing
interface Vlan1
ip address 10.0.6.1 255.255.255.0
ip pim dense-mode
ip nat inside
no ip virtual-reassembly in
end
interface Vlan50
ip address 10.0.5.1 255.255.255.0
ip pim dense-mode
ip nat inside
end
interface ISM0/1
description Internal switch interface connected to Internal Service Module
switchport mode trunk
no ip address
end
Does anybody has any thoughts?
Everyone's tags (3)
Re: Apple TV vs WLC on ISM-SRE-300
the multicast address on the WLC is configured as 239.254.0.3
vlan 1 on 2911 is untagged and is used to communicate with WLC mgmt address 10.0.6.2
from my 2911 I can see the following
ar-lv-br1#sh ip mroute
IP Multicast Routing Table
Flags:...r
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.254.0.3), 16:04:13/stopped, RP 0.0.0.0, flags: DP
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list: Null
(10.0.6.2, 239.254.0.3), 16:04:13/00:02:55, flags: PT
Incoming interface: Vlan1, RPF nbr 0.0.0.0
(*, 224.0.1.40), 16:08:31/00:02:36, RP 0.0.0.0, flags: DCL
Vlan1, Forward/Dense, 15:54:23/stopped
"show run-config" from the WLC
the show run-config" from the WLC is attached to my previous commet
WLCM_conf.txt.zip
Does anybody has any ideas?
The case is extremely urgent!
the problem is solved!
we have 3 interfaces at our router
  • vlan1 - for wlan mgmt
  • vlan 50 - for wifi users
  • g0/1.40 - for LAPs
multicast was enabled only between vl1 and vlan 50
enabling multicast (ip pim dense-mode) on g0/1.40 resolved the issue
917
