09-05-2013 03:59 PM - edited 07-04-2021 12:46 AM
Hi my name is Ivan
I would like to know if there are any cisco wireless product that allows user to view applications in the wireless network are used and how much bandwidth is consumed per user and per application.
Thanks for your reply.
Thanks.
09-05-2013 05:36 PM
You can look at AVC on the wlc's starting on v7.4. Here is a guide which you can look at and see of it provides with with some of what you are looking for.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bed910.shtml
09-05-2013 10:47 PM
Once you configure AVC on your controller you can export netflow data from you controller to a netflow collector. Then you can get an historical trend on utilization of your wireless network based on recognized application. Without a netflow collector you can monitor Application visibility in each controller in real time, but you cannot get a holistic view of your environment if you have multiple controller.
Not all netflow vendors support cisco WLC flow export. I have tested this with Scrutinizer and they were the only vendor support this in few months back. You can refer below to see how it looks like
http://mrncciew.com/2013/03/13/review-of-wlc-netflow-with-scrutinizer/
If you have Cisco Prime Assuarance, then also you can do the same without having 3rd party netflow collecting tool.
Rasika
09-06-2013 04:44 AM
Q. What is Cisco Application Visibility and Control?
Q. How does AVC work?
Q. What technology is used in the AVC solution?
A. Cisco AVC consists of the following technologies:
• Network-Based Application Recognition Version 2 (NBAR2), next-generation DPI technology that can identify more than 1000 applications and support application categorization, with the ability to update the protocol definition.
• NetFlow Version 9 export to select and export data of interest, allowing easy consumption of application performance statistics by Cisco and third-party applications.
• Reporting and management tools, such as Cisco Prime™ Infrastructure with Assurance module, an enterprise-grade infrastructure and service-monitoring tool for reporting of application and network performance that can provide up to 30 different reports for application visibility.
• QoS to facilitate the control of application perform
For more info please refer
