Are these Access Points upgradable to LWAPP mode???
I was wondering which of the following access points are upgradable to LWAPP. Currently they are autonomous access points.
AIR-AP1231G-A-K9
AIR-AP1232AG-A-K9
AIR-AP1220B-A-K9
AIR-AP352E2R-A-K9
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Are these Access Points upgradable to LWAPP mode???
Hi Nolan,
AIR-AP1231G-A-K9 = Yes
AIR-AP1232AG-A-K9 = Yes
AIR-AP1220B-A-K9 = No
AIR-AP352E2R-A-K9 = No
Migration from autonomous access point mode to lightweight mode is possible on these Cisco Aironet access point platforms:
•All 1121 access points
•All 1130AG access points
•All 1240AG access points
•All 1250 series access points
•For all IOS-based 1200 series modular access point (1200/1220 Cisco IOS Software Upgrade, 1210 and 1230 AP) platforms, it depends on the radio:
-if 802.11G, MP21G and MP31G are supported
-if 802.11A, RM21A and RM22A are supported
The 1200 series access points can be upgraded with any combination of supported radios: G only, A only, or both G and A.
Note For an access point that contains dual radios, if one of the two radios is an LWAPP-supported radio, the upgrade tool still performs the upgrade. The tool adds a warning message to the detailed log that indicates which radio is unsupported.
•All 1310 AG access points
•Cisco C3201 Wireless Mobile Interface Card (WMIC)
Note The second-generation 802.11a radios contain two part numbers.
Access points must be running Cisco IOS Release 12.3(7)JA or later before you can perform the upgrade.
From this good doc;
Upgrading Autonomous Cisco Aironet Access Points to Lightweight Mode
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
Hope this helps!
Rob
1 REPLY
Hi Nolan,
From this good doc;
Hope this helps!
Rob
477
