Community Member
ASA 5510 with WLC 526. DHCP Problem.
I'm having problem with ASA 5510 and WLC 526, in  this case the ASA provides DHCP, I created 3 vlan's (12 administrative,  13 visits, 10 AP's). WLC 526 has two network interface, eth0 in this vlan  10, and eth1 is in a TRUNK port on the switch in valn 12 and 13. The fact is that  when a user attempts to connect to wireless network does not take  DHCP, but setting a fixed ip connection works perfectly.
One problem is that the WLC has 526 limited-config below.
These commands available:
(Cisco  Controller)> config?
Advanced Advanced  Configuration.
(Cisco Controller)>  config advanced?
802.11a 802.11a  parameters.
802.11b 802.11b parameters.
Auto client-handoff handoff clients on the excessive retires.
dot11-Set padding over-the-air frame padding
eap EAP (Extensible Authentication Protocol) Settings
macfiltering macfilter Configure advanced settings.
max-1x-sessions  Maximum 802.1x session initiation per AP at the time.
probe-limit  limit number of probes to sit AP per switch slot per client in a Given  interval.
rate Enable / Disable switch  control path rate limiting.
Statistics  Enable / Disable switch port statistics.
Configures  timers, system timers.
Mini IOS  Version .............................
........................... IOS Version 12.4 (10b) JX
Attached below the debug WLC dhcp message, and runnig config.
Everyone's tags (4)
Re: ASA 5510 with WLC 526. DHCP Problem.
I'm not familiar with the 526, but I've run into this with a 2106 and an ASA.  Basically the ASA won't serve DHCP to a proxy.  On the 2106 you can disable DHCP proxy with "config dhcp proxy disable".
Community Member
this  option does not exist in WLC526, I think that really has no way to work  with the ASA.
