[Ask please]About Cisco Aironet AIR-AP1121G-A-K9
Suwandy.Ong
Guys, my company bought a cisco wireless and told me to set it.
It is a Cisco Aironet AIR-AP1121G-A-K9.
my company has one SSID: it is called ADRW. All the wireless's are using the same SSID. And it is hidden so it's not broadcasted..
Set it already all right, but when I tested it, I can't get it to connect. Is it something wrong with my setting? If I change the SSID to something else, for example ADRWX or ADRWXX, it will connect.. Anybody has a clue or something?
Thanks a lot
Suwandy
3iadministrator
maybe you can tell us more about your AP or the WLC setup involved (if any).
Thanks for the kind reply, 3iadministrator..
Apparently, I have succeeded to set it up. I changed it to the different SSID, and tested it on my host.
Then, I changed it back to my original SSID which I need, and it's worked now. Maybe it has to be warmed up a little bit
Suwandy
Hi Suwandy,
Not a problem, I have not work on autonomous AP before. maybe i should try that someday on my spare AP.
thanks
J
