08-07-2003 06:38 AM - edited 07-04-2021 08:55 AM
I have an 1200 Aironet Access Point and 350 series Client adapter. I authenticated user by Cisco ACS 3.1. It's possible to assign IP Address to client using ACS radius extensions?
Any suggestion are welcome...
08-14-2003 07:58 AM
Yes you can assign IP address to clients using ACS, check out the following document on how to do it, http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs31/acsuser/g.htm
12-09-2003 11:04 AM
Hi,I have the same problem with AP 1100 and 350,
If you discover a solution for ip assignment to wireless client adapter with ACS 3.1, please send me the response to ecornejo@magenta.cl
Best Regards.
Eduardo.
