Attempting to Add LAP1252AG APs to wireless network
psiegling
We are bringing up a building with 7 new 1252 APs. They are using inline power from a new 3750E-48PD-SF at 12.2(44). The WLC is a 4404 running 4.2.217.
The 1252s will not complete a boot, and make the console prompt available. Below is the text the appears on the AP console as the unit resets. This cycle is repeated over and over.
%LWAPP-5-CHANGED: LWAPP changed state to JOIN
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
%LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
%LWAPP-5-CHANGED: LWAPP changed state to CFG
%LWAPP-5-CHANGED: LWAPP changed state to DOWN
%LWAPP-5-CHANGED: LWAPP changed state to UP
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
%LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
%LWAPP-3-CLIENTEVENTLOG: AP has joined controller EN-WAPCTRL-01
%WIDS-6-ENABLED: IDS Signature is loaded and enabled
%CDP_PD-2-POWER_LOW: All radios disabled - NON_CISCO-NO_CDP_RECEIVED (0000.0000.0000)
The IOS then starts to reload. The WLC sees the AP, but as soon as the reset starts, the WLC removes it from the AP list.
The 3750E is configured to provide 20000 inline power. Since the AP will not stay in the WLC AP list, we can not configure it to use max power. All APs when joining default to 15.4 med power.
Ideas? A TAC is opened on this. No suggestions forth coming. It has been a week.
Thank you...
6 Replies 6
ericgarnel
Level 7
Level 7
How is your switchport configured?
Here is ours (3560E) and it works fine with th 1252 radios w/ both modules
interface GigabitEthernet0/20
description MR 4B 1252 AP
power inline port maximum 20000
switchport access vlan 20
switchport mode access
mls qos trust dscp
and inline power:
H203#sh power inline
Available:450.0(w) Used:200.0(w) Remaining:250.0(w)
Interface Admin Oper Power Device Class Max
(Watts)
Gi0/1 off off 0.0 n/a n/a 15.4
Gi0/2 off off 0.0 n/a n/a 15.4
Gi0/3 off off 0.0 n/a n/a 15.4
Gi0/4 off off 0.0 n/a n/a 15.4
Gi0/5 off off 0.0 n/a n/a 15.4
Gi0/6 off off 0.0 n/a n/a 15.4
Gi0/7 off off 0.0 n/a n/a 15.4
Gi0/8 off off 0.0 n/a n/a 15.4
Gi0/9 off off 0.0 n/a n/a 15.4
Gi0/10 off off 0.0 n/a n/a 15.4
Gi0/11 off off 0.0 n/a n/a 15.4
Gi0/12 off off 0.0 n/a n/a 15.4
Gi0/13 off off 0.0 n/a n/a 15.4
Gi0/14 off off 0.0 n/a n/a 15.4
Gi0/15 auto on 20.0 AIR-LAP1252AG-A-K9 3 20.0
Gi0/16 auto on 20.0 AIR-LAP1252AG-A-K9 3 20.0
Gi0/17 auto on 20.0 AIR-LAP1252AG-A-K9 3 20.0
Gi0/18 auto on 20.0 AIR-LAP1252AG-A-K9 3 20.0
Gi0/19 auto on 20.0 AIR-LAP1252AG-A-K9 3 20.0
Gi0/20 auto on 20.0 AIR-LAP1252AG-A-K9 3 20.0
Gi0/21 auto on 20.0 AIR-LAP1252AG-A-K9 3 20.0
Gi0/22 auto on 20.0 AIR-LAP1252AG-A-K9 3 20.0
Gi0/23 auto on 20.0 AIR-LAP1252AG-A-K9 3 20.0
Here are the switch inline power settings:
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 n/a n/a n/a
2 850.0 0.0 850.0
(Watts)
Gi2/0/1 auto off 0.0 n/a n/a 15.4
Gi2/0/2 auto off 0.0 n/a n/a 20.0
Gi2/0/3 auto off 0.0 n/a n/a 20.0
Gi2/0/4 auto off 0.0 n/a n/a 20.0
Gi2/0/5 auto off 0.0 n/a n/a 20.0
Gi2/0/6 auto off 0.0 n/a n/a 20.0
Gi2/0/7 auto off 0.0 n/a n/a 20.0
Gi2/0/8 auto off 0.0 n/a n/a 20.0
Gi2/0/9 auto off 0.0 n/a n/a 15.4
Gi2/0/10 auto off 0.0 n/a n/a 15.4
Gi2/0/11 auto off 0.0 n/a n/a 15.4
Gi2/0/12 auto off 0.0 n/a n/a 15.4
Gi2/0/13 auto off 0.0 n/a n/a 15.4
Gi2/0/14 auto off 0.0 n/a n/a 15.4
Gi2/0/15 auto off 0.0 n/a n/a 15.4
Gi2/0/16 auto off 0.0 n/a n/a 15.4
Gi2/0/17 auto off 0.0 n/a n/a 15.4
Gi2/0/18 auto off 0.0 n/a n/a 15.4
Gi2/0/19 auto off 0.0 n/a n/a 15.4
GigabitEthernet2/0/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 001e.13d0.ac82 (bia 001e.13d0.ac82)
Description: EN-WAP-HAYFIELD01
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
Media-type configured as connector
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
12873 packets input, 2007863 bytes, 0 no buffer
Received 6215 broadcasts (1275 multicasts)
0 watchdog, 1275 multicast, 0 pause input
1130150 packets output, 283217971 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
Do a 'sh logg' and look for the following:
%ILPOWER-7-DETECT: Interface Gi0/22: Power Device detected: IEEE PD
Apr 8 09:01:56: %ILPOWER-5-POWER_GRANTED: Interface Gi0/22: Power granted
You may also try deugging it:
H203#debug ilpower ?
cdp ILPOWER CDP messages
controller ILPOWER controller
event ILPOWER event
ha ILPOWER High-Availability
police ILPOWER police
port ILPOWER port management
portpowermax ILPOWER port power max
powerman ILPOWER powerman
registries ILPOWER registries
scp ILPOWER SCP messages
sense ILPOWER sense
or the port:
debug interface GigabitEthernet2/0/2
psiegling
Issue has been resolved. The 3750E switch requires two CLI configs for each interface to support the AIR-LAP1252AG-A-K9 access points. The commands are
Config interface GigabitEthernet2/0/8 (one of the interfaces that AP is on)
(config-if)# power inline port max 20000
(config-if)# power inline auto max 20000
Repeat this for each interface an AP is to be attached to. Do not forget to write the changes.
These commands are needed on all 3570E, and 3560E switches. At least this is what I heard from the TAC.
The second line may be a default command on the 3560-E switches as I do not see it listed on my switch configs and yet I have several 1252-laps working fine with just the 1st command
Hi All,
In my lab environment, this command is required,
but you also must change the default CDP packet interval from 60sec to 5 sec, let AP receive the switch CDP packet when AP negotiate power level in boot up status.
try it!!
Amber
