Autonomous APs to LWAPP
I have a project to upgrade the current Autonomous APs 1242 running on a customer site and they want them to be converted to LWAPP and moved over to controller.Is there a way to convert them? Note the APs are about 12-15ft high in the ceiling.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Autonomous APs to LWAPP
Unless you know some IOS upgrade commands, I'd recommend you stick with the Upgrade Tool.  The "archive" command is used to upgrade the firmware from your TFTP server to the appliance where you are running the command from.
Gold
You could either use the LWAPP upgrade tool or just use the archive command to load the LWAPP conversion image to the AP.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
cisco upgrade tool is available on  cisco web site you can download it and then you need to create a text file which you want to convert them.format is given below
This is simplest way to convert.
Helping document
thanks
Tahir
Do I need to remove the existing config off the APs and can I keep the current IP Address?
Depending on the firmware your WLC is running it is possible.  If you look at the Conversion Tool there is a tick box to keep the static IP address.
What's the archive command?  Thanks
1892
